hella 500s installed
Old Nov 29, 2008 | 05:52 PM
damien1023's Avatar
damien1023
Originally Posted by Ridinhigh
i love how those look how much does a set of those costs and how hard was the install those all look bada$$ props ro you guys
i took my time so that i could line everything up and hide all the wires so it took me about 2.5 hours taking my time. as you can see in the 3rd pic from my first pic i put wire loom to hide all the wires and i didnt have the right size drill for the switch so i made a "jig" on a piece of 2x4 and had to use a wood drill bit so i could get the right size hole. it was hard because if you look at the switch it doesnt have a very big lip so if you screw up it will probably show the imperfections and i like all my installs to look as clean as possible (not saying anyone elses install is not clean). but yeah all in all took about 2.5 hours taking my time
Old Nov 29, 2008 | 11:16 PM
Ridinhigh's Avatar
Ridinhigh
nice i could deffinatly do that soon if its only 55 bucks for the lights and i can take the 2.5 hours to do a good install like yours damien
Old Nov 30, 2008 | 12:18 AM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by seawind3000
I am wiring my Hellas (HID bulbs) , the fog lights (HID bulbs) and the low beam HIDS all to the Hi beam switch so it all lights up on hi beam and only the low beams on low ,so I don't pi** everyone off with the extra lights. I don't want to be looking for switches every time a car comes around the corner. Here you are only allowed to have one set of lights on at any one time. Even headlights and fogs will get you pulled over.
Good luck on figuring that one out. It's all ecu controlled. if you do get it working please let us know because I cannot seem to figure it out how to even hae the foglights remain on with highbeams without going to a dealer that will help out with the starscan.
Old Nov 30, 2008 | 12:34 AM
ried69's Avatar
ried69
After seeing all the pics and all, I think that I'm convinced to do that myself here soon.
But as a question to you guys with them, first, I believe that I still have the stock battery in my truck, which is an '03. Should I replace that first? Second, what all comes with the lights? Is it all the wires, I just need the harnesses and a switch, or what? Also, because I've seen in our Wal-mart that they have a large arrangement of lights, does the box say Hella 500 on it? Just wanna make sure of that so I don't mess up and purchase the wrong lights. I'm one to always double and triple check to be sure of things first so I don't mess up.
But the lights look awesome.
Old Nov 30, 2008 | 08:21 AM
damien1023's Avatar
damien1023
here is the box. my store had the hella 500 which is what i got and the hella 500ff. the FF just has a totally clear lens and costs a few more bucks. the lights come with everything. lights, rock blockers, relay, wires, brackets and switch. if you dont have any extra wiring stuff you might want to pick that up (extra wire, connectors, etc) just in case. the battery thing is up to you, if its the original battery its been 5 years so its probably about time to replace it anyway...
Old Nov 30, 2008 | 11:47 PM
ried69's Avatar
ried69
Alright, thanks for posting that. I'm going to replace the battery here before January, but I'm waiting off until I get my fall paycheck to really buy anything. I want to replace it because my gauge shows that my volts are quite a bit higher than that center mark, and I don't want to be caught out in the cold with a dead truck. So I think I might do the battery and then the lights, or both at the same time since I'll be working under the hood anyway.
Old Dec 2, 2008 | 09:32 PM
Grey-Ghost's Avatar
Grey-Ghost
hella 4000 converted to hid with ebay kit could do the same with 500s check the pics http://yotatech.com/f131/hella-4000s...ed-hid-144713/
Old Dec 2, 2008 | 10:33 PM
damien1023's Avatar
damien1023
thats cool, i will admit that the one thing i wish the 500s did was have a wider beam pattern. other then that they are great
Old Dec 2, 2008 | 10:46 PM
Grey-Ghost's Avatar
Grey-Ghost
did u check the link with the other pics its amazing and all he did was buy a 75 hid kit off of ebay and put it in the light
Size:  61.5 KBName:  CIMG1288.jpg
Old Dec 3, 2008 | 12:08 AM
Ridinhigh's Avatar
Ridinhigh
this is sweet the 500's are a pencil beam are they not more for spottlighting and can the stock head lights recieve an hid bulb
