Front Leveling Kits - 2WD
http://www.topguncustomz.com/Store/products.php?S_ID=48
tbsm, I'm not sure if it's the same for the megacab. I may be wrong, but I think the megacab is more like the 2500 than the 1500. Check out this link and you can find a 1.5" spacer for your truck for $40!!!!! Give it a shot.
i got the 2" spacer from FatBobs...if you look at the thread me and Cowboy shared, you could see that I had ALL KINDS of trouble out of my 07 2wd
Horrible ride, brake lines are too short. Dont skimp out on the alignment by the way
And i bought +2" longer shocks by the way, I dont know if having stock size shocks out make a diff
I got the spacers from fat bobs and the longer shocks and I've been real happy with it. the trick looks great but I actually had to get a 1 inch block for the back because I put the stock spacers on top of the new spacers.
yea but the 06-08 have a slightly different setup, the control arm is quite a bit thicker and the edge is close to the spring bucket and actually hits. Im guessing thats what the problems is at least
