HID installation help
Old Dec 3, 2008 | 03:02 PM
mremp's Avatar
mremp
Default HID installation help
Hey guys i have an 07 dodge ram, and i bought HID conversion kits for my headlights, and fog lights. Now i want to install them and im just not sure what to do first, is there any write ups on installing hids in my specific truck?
Old Dec 17, 2008 | 09:36 PM
lscottol's Avatar
lscottol
just got my Hids and Im ready to install. heard there is alot of problems with o4 and up with grounding and keeping the power up. heard you could do a few different things to fix. any sugge/
Old Dec 17, 2008 | 11:22 PM
bulldoghemiram04's Avatar
bulldoghemiram04
Don't know about the 07, I have 04 with HIDs in the headlights and fogs, had no problems ground them, just make sure that there is no paint where you ground it at(I used OEM grounding locations). For the headlights, you can install the bulb on the passenger side without pulling the headlight out of the truck, cant say that for the drivers side(three bolts,two on the left side of the headlight assembly and one on the right lower side, you can see it if you look between the headlight and the top of the bumper.) The HID kit should have come with a connector kit that is pretty much plug and play. Remember DONT TOUCH THE BULB!!!!!!! As for the fog lights you can get to them from under the truck. This should be the end result.
04 qb lerime hemi 2wd
bullydog power programer
4pc cold air intake
super 44w/cutouts
jl audio w7, 1000w amp
Old Feb 28, 2009 | 08:35 PM
viperman1's Avatar
viperman1
Hi: What are these 2 lights seen inside the grille
Old Feb 28, 2009 | 10:00 PM
traker1001's Avatar
traker1001
He has Fogs mounted to the crossmember behind his grill, Common and easy addon.
You need HID's in them to.
Old Mar 1, 2009 | 04:44 PM
sharkhunter10's Avatar
sharkhunter10
its not to hard to wire the hid's up on an 07 I have one and did it but you must have a relay for them or they wont work on the 07. I have a diagram I made it might help to wire them up
Old Mar 2, 2009 | 10:16 PM
viperman1's Avatar
viperman1
Default I have a 2004 hemi 1500, HID Install question
Does anyone have a picture of the wire harness for the 9007 bulb install on the 04 Ram ?
I belive the harness requires at least one capacitor to prevent the flickering.
Any imputs are appreciated, Thanks
Old Mar 2, 2009 | 11:20 PM
sharkhunter10
All the dodges have to have the Relay to prevent the flickering and for them to work as you drive you dodge here is a diagram for the HID Ballast and Relay.
Old Mar 2, 2009 | 11:39 PM
sharkhunter10
this is what my 6000K Fog and Head Light HIDs look like!
Old Mar 2, 2009 | 11:45 PM
ried69's Avatar
ried69
What would happen if you would touch the bulbs of the HIDs? I remember when we put up the halogen light on our back garage, my dad said to not touch it. Is it because of the oil on your hands might shorten the length of the light bulb?
