Gears ?
Old Dec 5, 2008 | 09:23 PM
minyo16's Avatar
minyo16
NVM haha but out of them two. will it save me gas? what one is better and out of this slection what one do you like? i have limited money. http://www.4wheelparts.com/search.aspx?kw=Auburn+LSD+ and would you go with this over a superchip
Old Dec 6, 2008 | 01:39 AM
lxman1's Avatar
lxman1
Site Moderator
http://nationaldrivetrain.com/shopsi...RYSLER925.HTML
Old Dec 6, 2008 | 10:50 AM
dodgenitto's Avatar
dodgenitto
Originally Posted by minyo16
Auburn LSD or a Detroit Tru Trac what are these? and i have the same tires as you do in the pic i love them. never been stuck. im trying to get pics up on here soon but just havent got to it. also i live in ithaca with a **** tone of hills is t still worth me getting the gears? and and brand i should go with?
I answered you in a pm
Old Dec 6, 2008 | 12:53 PM
metalwolf69's Avatar
metalwolf69
How much does the install on tru trac and gears cost? Just a round bout cost so i know im not gettin screwed
Old Dec 6, 2008 | 06:32 PM
dirtydog's Avatar
dirtydog
Moderate User
I don't think 4:88's will fit on the stock carrier. You would have to upgrade. 4:56's can be installed with the stock carrier so all that you would need are the ring and pinions plus the shimming kit. Also, with the 4:88's you really would want stronger axles. If I were to install gears, I would get 2-detroit TrueTrac carriers and 2 sets of 4:56 gears/install kits. That's the right way to do it. With that set-up plus labor will run you $2500 total for everything. The carriers are $500each No clutch packs, no friction modifier needed, no chattering, no lock/unlock noises, no bucking or jumping when they kick in/out like alot of clutch packs or pure lockers do. These things are super smooth and you'll feel like you have your stock carriers in there. They are awesome.
Old Dec 7, 2008 | 12:05 AM
dodge it then ram it's Avatar
I dont think you can put a Trutrac in the front. I dont think it uses an lsd up front. I may be wrong though. Dodgenitto can answer this for me. You
reading this Dodgenitto?!?! Yeah Im talking to you!
Old Dec 7, 2008 | 12:17 AM
dodgenitto's Avatar
dodgenitto
approx $1800
Old Dec 7, 2008 | 12:20 AM
dodgenitto's Avatar
dodgenitto
I am listening!!
if your dodge truck is IFS (then you can only find it for the rear!) Detroit does not make a LSD for for dodge IFS. Spend $6000 on a solid axle swap, then go for it!
Old Dec 7, 2008 | 01:20 AM
WeightLifter500's Avatar
WeightLifter500
They don't make any LSD's for up front? I know a guy that has I believe an 01 ram with tru tracs in the back and the front. It is a beast in the mud because all four tires are actually in use.
Old Dec 7, 2008 | 10:33 AM
dodgenitto's Avatar
dodgenitto
does his 01 have a solid front axle? that might be why he was able to have them front and rear.
