Tru-lock?
Old Dec 6, 2008 | 06:27 PM
HammerZ71's Avatar
HammerZ71
You'll pay about $200 for a rear ring and pinion, about $225 for a front ring and pinion, about $100 for a master install kit and about $350-$450 for a rear LSD depending on whether you look at an Auburn or Detroit unit. So, you'll be at about $900 for all the parts, then you'll have to get a price for the labor...
Old Dec 6, 2008 | 09:18 PM
WeightLifter500's Avatar
WeightLifter500
Not unless you put the Tru-Tracs in the front and back. lol Is it even worth putting an LSD in the front if I don't do alot of off roading? Would it be a good idea to put a tru-trac in the back and save some money by putting the auburn in the front?
Old Dec 6, 2008 | 11:06 PM
dodgenitto's Avatar
dodgenitto
Originally Posted by metalwolf69
Hey I got 2 questions really.. First one is what is the part i need to get both rear tires to spin together, when im flooring it only the right rear spins not both sides?
Plus I called my dealer bout changing from 3.92 gear to 4.56 gear, I neared crapped myself when i was told a couple grand for both axles? What did u guys pay? Was this guy really just jerking me around? Thanks 8)
You are talking about a LSD (limited slip differential) I paid under 2000 for 4:56 gears front and back and a Detroit Tru Trac in the rear diff! The stealership will charge you more then anyone else! I can't remember exactly but it was around 1600-1800 bucks
Old Dec 6, 2008 | 11:10 PM
dodgenitto's Avatar
dodgenitto
I have never seen a LSD for the front diff on an IFS truck! It has independent axels and I don't think they make them for it! If you want a lsd for the front then you better fork out $6000 for a solid axel swap!
Old Dec 7, 2008 | 03:38 AM
abarmby's Avatar
abarmby
dodgenitto is correct.
There is no LSD for an IFS Dodge Ram 1500 that I know of ?
As for welding up the carrier????
My friend did that to a huge 4X4 rock crawler on a massive Rockwell axle.
He had to do it "on the cheap".
There was enough welding in that sucker, to sink a battle ship and the welds still broke off!
He was lucky, in that it didn't screw with his pinion or anything.
It's a TOTALLY bad idea.
Get a set of matching gears if you have a 4X4 and a DTT and you will be good to go for the street my friend.
If you have a 2WD jut a rear set of gears and a DTT will set you up also.
Hope this helps?
Al.
Old Dec 7, 2008 | 11:52 AM
metalwolf69's Avatar
metalwolf69
Thanks guys!
Old Dec 7, 2008 | 12:27 PM
dirtydog's Avatar
dirtydog
Moderate User
I wasn't thinking about the IFS! Good point.
I was just so used to reading the 4x4 offroad magazines I got lost...lol I keep forgetting I have a street freindly 4x4...hehehe
Old Dec 7, 2008 | 02:00 PM
SmokeySportRam's Avatar
SmokeySportRam
yeah, whats wrong with a mini-spool?
ha
Old Dec 9, 2008 | 03:02 PM
Hoss356's Avatar
Hoss356
nothings wrong with a mini-spool but both wheels will ALWAYS be turning the same speed so you won't have a street friendly truck, mini spools are great for trailered off road trucks that you won't be driving on pavement. Welding the spider gears is a dirt cheap old school fix that's also known as a "lincoln locker" and it effectively makes it a spool, a lot of people have gotten away with that one, I sure as hell wouldn't use it in anything but a 500 dollar beater that's just for thrashin because it will never be as strong as any manufactured part you can buy. Look into the ARB air lockers, they act as an open diff during normal driving and a locker when you need more traction.
Old Dec 9, 2008 | 03:08 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
lol, i def think he was joking.
ther is absolutely no need for a front LSD on a truck with a solid through transfer case.
putting an lsd in the rear and a solid T/C affectively locks the front as well, unless you somehow manage to spin the two front wheels opposite directions at the same speed
