Tru-lock?
Old Dec 5, 2008 | 06:20 PM
metalwolf69's Avatar
metalwolf69
Default Tru-lock?
Hey I got 2 questions really.. First one is what is the part i need to get both rear tires to spin together, when im flooring it only the right rear spins not both sides?
Plus I called my dealer bout changing from 3.92 gear to 4.56 gear, I neared crapped myself when i was told a couple grand for both axles? What did u guys pay? Was this guy really just jerking me around? Thanks 8)
Old Dec 5, 2008 | 07:28 PM
nim81's Avatar
nim81
as for the rear axle you could always get a selectable locker.
and as for the gear swap. try randys ring and pinion.
i would say for gears and install, around $1500+/-.
Old Dec 5, 2008 | 07:51 PM
dirtydog's Avatar
dirtydog
Moderate User
Not including the actual lockerunit. Most lockers are about $350-$600 depending on what you get. Gear changes to the rear have to be made to the front. You don't have to match the lockers, just the gears.
Old Dec 6, 2008 | 12:10 PM
metalwolf69
Ahh So I can just get a locker for the rear. i dont have to get one for the front..
thou i do need to get 4.56gears for the front and the back....
thanks
Old Dec 6, 2008 | 12:47 PM
galvatron's Avatar
galvatron
yep they gotta match
Old Dec 6, 2008 | 12:52 PM
sschevy400's Avatar
sschevy400
Originally Posted by metalwolf69
Hey I got 2 questions really.. First one is what is the part i need to get both rear tires to spin together, when im flooring it only the right rear spins not both sides?)
A welder, and about 30 min!!!
I feel your pain, when i got my 08 the first thing i looked for was it had to have the Hemi...and the second was the Posi.....
good luck
Old Dec 6, 2008 | 01:31 PM
meridian's Avatar
meridian
good luck
A welder, and about 30 min!!! LMFAO! My way for fast launch, 4hi in first gear, floor brake and accelerator and then let go of the brake! No wheelspin and costs nothing! Unless you kill your transfer case that is!
Old Dec 6, 2008 | 01:57 PM
dirtydog's Avatar
dirtydog
Moderate User
good luck
Worst advice yet!
Did you weld up your carrier? Prob. not!
Weld the gears up and then have the torque break the weld free and it will eat up everything and/or lock up going down the road. it can ruin your entire differential, gears, bearings...etc. There's a reason people don't do that crap. Aside from the fact you'll wear tires out driving on the road in no time and have your tires screeching around every turn. Not good for anything!!!
You must match the gear raitio's and yes you can get just the rear locker and keep the stock front carrier with the new gears. It's better to just get a new carrier because you have to take it out to changes everything anyways. If you ever decide to upgrade the front carrier to what you have in back, your gonna have pay the price of a complete gear change pretty mcuh as the backlash and depth may have to change.
Don't quote me on this, but I believe a carrier like TrueTrac that Detroit makes will actually help with the turning while in 4wd. I don't think you'll bind as much and you'll be better off even if you were to drive on bare pavement. The Detroit TrueTrac is a great locker. It's a worm gear that needs no additives and has zero chatter. You cannot hear anything when it locks. It's unlike the other lockers that you can hear while going around a turn...etc and can get annoying for the non-avid user. Detroit TrueTrac has no clutch packs to burn or chatter!
http://cgi.ebay.com/ebaymotors/DETROIT-TRUETRAC-CHRYSLER-9-25-DODGE-RAM-1500-913A368_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el 1247QQcategoryZ33731QQihZ001QQitemZ110259926072QQr dZ1QQsspagenameZWD1V
Old Dec 6, 2008 | 02:19 PM
meridian's Avatar
meridian
Originally Posted by dirtydog
Worst advice yet!
I think he was joking! Well I hope he was! Thanks for the addy. I added him to my favourites.
Old Dec 6, 2008 | 06:24 PM
dirtydog's Avatar
dirtydog
Moderate User
I don't think he was!
