Sticky throttle 2004 Ram
Old Dec 11, 2008 | 03:38 AM
Jimmy Lewis's Avatar
Jimmy Lewis
Default Sticky throttle 2004 Ram
My throttle pedal is really sticky. Pushing on it it is like a retcheting device and it is very difficult to make it smooth. I'l tried some WD40 on the pivot points with no luck. It returns fine but I'd like a smoother push.
Anyone had problems like this?
Any solutions?
JIMMY
Old Dec 11, 2008 | 09:23 AM
OlDirtyJohn's Avatar
OlDirtyJohn
got the same exact problem in my 2004. its really stiff at certain points. so when im trying to take off at a really slow speed, like in a parking lot, i gotta press pretty hard to get it going, then once it starts going im hauling ***. ill definitely be following this thread
Old Dec 11, 2008 | 09:51 PM
draco8494's Avatar
draco8494
are these prob on the hemi? i dunno if the 4.7 has the "fly by wire deal" like the hemi but if not ide clean the TB and lube all the linkage n such...if on the hemi try a 3 in one lubricant instead of WD-40
Old Dec 11, 2008 | 10:03 PM
4x4HemiFreak's Avatar
4x4HemiFreak
yea i have the same promblem with my 04 as well it some times will take off soooo slow and then it will later on get easier but i though i herd something bout a recall on the pedals a while back not sure if its true or not...
Old Dec 11, 2008 | 10:47 PM
irelandshemi's Avatar
irelandshemi
cant tell you about the pedals or anything recalling but if you havent cleaned your TB yet i would
Old Dec 14, 2008 | 08:17 PM
bulldoghemiram04's Avatar
bulldoghemiram04
if you have a 5.7 DON'T CLEAN IT WITH THROTTLE BODY CLEANER, it will do more damage to the throttle body if the wd40 hasn't already, its printed on the side of the throttle body!!!, last I checked they about 300 dollars from mopar. If you have a 4.7 its ok to clean, if that doesn't fix it you could have a problem with the cable.
Old Dec 15, 2008 | 08:33 PM
OlDirtyJohn
there isnt a cable going to the throttle body, its drive by wire. unless you are talking about the wires. which i dont think electrical wires would cause a sticky pedal. and im not 100% sure, but i think they dont want you cleaning it because of the electronics on it. i cleaned mine, and was careful not to get any fluid on the electronics housing part of it and that solved my problem.
Old Dec 15, 2008 | 09:00 PM
bulldoghemiram04
the 4.7 are cable accuated. the 5.7 are fly by wire. wasnt sure what engine he had. if its 5.7 with a sticky pedal the only thing to do about it is replace the pedal!!
Old Dec 15, 2008 | 09:06 PM
dazed01's Avatar
dazed01
Some throttle body cleaner on a rag and wiping around inside the throttle body should fix that. If you pull the intake tube off you will probably see an accumulation of carbon, clean that off.
Old Dec 15, 2008 | 09:16 PM
OlDirtyJohn
i dont think replacing the pedal is the only option. i had a sticky pedal. i cleaned the TB, and now all is well. no more sticky pedal.
