Just a dumb question.
Old Dec 17, 2008 | 05:36 PM
justanothermoparman's Avatar
justanothermoparman
Default Just a dumb question.
Could we put a 2500 PowerWagon rear axel on our 1500's?
Old Dec 17, 2008 | 05:44 PM
OlDirtyJohn's Avatar
OlDirtyJohn
i dont know if you can or not... but if you did, it still wouldnt give you the same load/towing capacities as a 2500. there is a lot more that goes into it than just the rearend. youd have to think about the heavy duty frame, suspension, and all that other good stuff that makes a heavy duty a heavy duty.
Old Dec 17, 2008 | 05:47 PM
lxman1's Avatar
lxman1
Site Moderator
It's probably the same as a MegaCab rearend. 8 lug vs 5.
Old Dec 17, 2008 | 08:08 PM
dodge it then ram it's Avatar
It is an 8 lug but there is more than that. 1500 rear axles are 9.25". I think 2500 uses a 10.25" or 10.5". You could transfer it with minor fabbing or maybe none at all. If the leafsprings sit at the exact same spot on both axles, mounting the springs onto the perches would be no problem. Same with brake lines, driveshaft connections, and shock absorber mounts. I'm not sure about the driveshaft connecting to the third member. Bolt patterns maybe different.
Old Dec 17, 2008 | 08:18 PM
nim81's Avatar
nim81
doesnt that axle have a selectable locker in it? that would be nice
Old Dec 17, 2008 | 09:25 PM
we_the_unforgiven's Avatar
we_the_unforgiven
Just put a locker in the factory rear axle if that's what you are after
Old Dec 17, 2008 | 11:12 PM
justanothermoparman
Thanks for your input, I was just after the stronger rear end 10.25 vs. 9.25, its much stronger and reliable. I could pick one up at the local junk yard for about $900 or a $1000 dollars.
Old Dec 17, 2008 | 11:49 PM
nim81's Avatar
nim81
well let us know if you decide to do the swap, sounds interesting
