03 4.7 help please!!!!
Old Dec 18, 2008 | 08:43 PM
bulletperformance's Avatar
bulletperformance
Exclamation 03 4.7 help please!!!!
ok i saw my ce light come on so i through my code reader on it and it says P0302 camshaft postion sensor.. i went to the local stealership and bought one.. WHERE IS IT????? a pic would be great thanks in advance
Old Dec 18, 2008 | 09:34 PM
SmokeySportRam's Avatar
SmokeySportRam
if i remeber right, its bolted to the front/top of the right cylinder head.
Old Dec 18, 2008 | 09:40 PM
SmokeySportRam
also, lube the o-ring with a small amount of engine oil when installing, and rock back and forth instead of twisting so you dont tear up the new o-ring.
Old Dec 21, 2008 | 04:19 PM
bulletperformance
thank you hopefully its easy enough and where are the plugs at as well
Old Dec 21, 2008 | 04:33 PM
SmokeySportRam
where are they spark plugs??
on the top of the motor, they go down in the intake, they are covered by individual coils
Old Dec 21, 2008 | 08:08 PM
froto'sride's Avatar
froto'sride
I will get you a pic as soon as my camera charges but for now look under your air intake tube on the left side of the engine. on the lower forward side of the head you will see it sticking out pointing almost toward the passenger side tire. the connector is grey. if you need more help locating it. look for the heater hose that come from the water pump housing on the passenger side of the block. once you see the look up toward the head and you will see it
Old Dec 21, 2008 | 09:10 PM
froto'sride
the easiest way to get to it is by lying on your back under your truck.
Old Dec 24, 2008 | 04:31 PM
bulletperformance
Thanks guys i appreciate it this is my first dodge truck. i WAS a ford guy but i wouldnt get caught driving a ford today i love my dodge been nothing but a dream for me it will go anywhere i go. What kind of spark plugs do you recommend?
Old Dec 25, 2008 | 08:33 PM
froto'sride
This is the best thing I have heard all year!! Not sure what to reccomend but don't be bosch dual sparks. I think the diamond fires are the best.
