O2 problems after new exhuast
I have an 03 Hemi 1500. I installed Edelbrock headers, Magnaflow cat, and flowmaster single 3" into 2.5" duals. I also installed new O2 sensors. I am recieving a P0132 code and the engine stumbles sometimes. I don't know if the computer is still getting used to the new set up or what. Any advice would help.
Is the Magnaflow a high flow cat? If so, you may have everything setup correctly and still get a CEL from the rearward 02 sensors as the air passing by is probably out of spec. A PCM reset may help, may not, worth a try. The stumbling engine is the PCM trying to adjust the A/F ration based on the information it's getting, which is no probably incorrect.
If not, do the non-fouler trick that you would do if you had cut out the cats. Should work for you too. I just told someone else about it in another thread.
I did a "DIY" on it a while ago, search for my "how to" in the "DIY" section, it's a simple, $10 and 1 hour fix...
Trending Topics
Good deal! I knew that search feature was good for sumthin'...
Hey, dirtydog: I think you need to say something to this guy. He used the Search Button!!!!!!!!
Inside joke, the 'dog has a pet peeve about people not using the search feature and to be honest, you are maybe only the second person that has posted where he's used the search to try and solve a problem in the last month or so.
BTW: My bad, I know damn well that Bosch's don't work, when your post said you replaced everything including O2 sensors, I should have asked & saved you some time. But when I saw "high flow cats", my only thought was using the non-fouler trick...
