6 speed 2500 hemi
Old Dec 24, 2008 | 10:49 PM
white2135's Avatar
white2135
Default 6 speed 2500 hemi
Two questions for you folks:
1. Is the 6 speed that is put behind the Hemi in the 3rd gen 2500's a NV5600? In other words, did they use the same 6 speed with the gas as with the diesel?
2. Do the 2006 and newer 2500's with manual transmissions also come with MDS? Or, was the MDS only available with the automatics?
Thanks!
Old Dec 24, 2008 | 10:57 PM
HammerZ71's Avatar
HammerZ71
I can't answer #1 off the top of my head.
But for #2, the 2500 has never been offered with MDS in either a manual transmission or an automatic. It's strictly used on all 1500s except the MegaCab model...
Old Dec 24, 2008 | 11:19 PM
white2135's Avatar
white2135
Not saying everything on the internet is accurate, but I've read that starting in '06, MDS was also available on the 2500 and 3500.:
http://www.thehemi.com/roadmap.php
Old Dec 25, 2008 | 01:18 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Why are you asking if you think you know the answer? Hammer is right BTW..
Old Dec 25, 2008 | 01:26 AM
white2135's Avatar
white2135
Never said "I" knew the answer did I? There is lots of wrong info on the net and I'm just trying to get verification of what the correct answer is.
Old Dec 25, 2008 | 09:16 AM
Gone Fishin's Avatar
Gone Fishin
#1)---No it's not the NV5600-----it's the G-56 Mercedes out of the commercial truck line. It's rock solid and almost indestructible. It's not for any sort of speed shifting!!!
All the gears are synchro'd--even reverse, and granny. I've got 92K on mine with absolutely no problems.
Old Dec 25, 2008 | 10:21 AM
manualagain's Avatar
manualagain
Gone Fishin i is correct with reference to #1. The 6-speed in the 1500 features a "normal" first gear, in the 2500, the first gear is a granny gear that you'd typically only use when hauling or towing a significant load.
Old Dec 25, 2008 | 12:08 PM
white2135's Avatar
white2135
So, was the G-56 used with all Hemi powered trucks since '03?
Old Dec 25, 2008 | 12:53 PM
Ben D.'s Avatar
Ben D.
yerppp.. getrag 238 is in the 1500's which is also indestructable. g56 comes in with 2500. either way stick shift it for the win.
Old Dec 25, 2008 | 11:27 PM
7mmmag1's Avatar
7mmmag1
A hemi isnt offered in the 3500, only the cummins
