Help! LED tailgate light bar
Old Dec 29, 2008 | 09:31 AM
BlueRam2006's Avatar
BlueRam2006
Default Help! LED tailgate light bar
My wife bought me a APC Tailgate light bar with reverse for Christmas. I attempted to install it this past weekend.
I spliced into the reverse light wire from the tail light and then plug the connector into the 4 pin trailer harness.
Everything looked good and before I mounted it I wanted to test it. When i tested the light bar only the tail lights worked. The brake lights, turn signals, and reverse lights did not work. Any ideas? Thank you
Old Dec 29, 2008 | 09:47 AM
JamesVT's Avatar
JamesVT
I bought one a while back (without reverse) from a company named Bully. It was crap. It took less then a month for the solder to break and one of the bars to stop working. But i also had some similar problems, Seemed that only my brake lights, and turn signals worked, the parking lights didnt work. I even changed the trailer harness connector, thinking it could have been corrosion in the harness. Still a no go. I don't think I'll buy another one..
Old Dec 29, 2008 | 09:55 AM
SeMiGoD's Avatar
SeMiGoD
double check your connections. cheap guess something came loose between test and actual mounting.
Old Dec 29, 2008 | 10:42 AM
BlueRam2006
I rechecked the connections multiple times and even checked the trailer harness with a Meter and everything looked fine
Old Dec 29, 2008 | 01:01 PM
RaiderJay6's Avatar
RaiderJay6
Sounds like the bar might be bad.
Old Dec 29, 2008 | 07:47 PM
SmokeySportRam's Avatar
SmokeySportRam
it the key on? does the normal reverse light come on when trying the led bar?
read the directions carefully, I installed mine and it didnt work, so I checked the direction and they use BLUE wire for ground instead of BLACK wire, how dumb is that?
Old Dec 29, 2008 | 08:48 PM
swinger525's Avatar
swinger525
Yes, I would check the wires again, or the ground.
Otherwise it sounds like the bar got screwed. I don't have one with reverse, mine is the solid red bar, and I only use the 4 prong trailer plug and it works great. Its been on the truck for 2 years, and I've never had a problem.
Although I didn't use the double sided tape feet, I just used stainless steel self tapping screws to attach it to the truck, that way if I need the spare I can just unscrew that, and theres the opening.
Old Dec 30, 2008 | 02:42 AM
abarmby's Avatar
abarmby
Quick way to check the bar, is to get a spare battery or use the trucks, and directly wire the ground on the bar to the neg terminal.
Then, pick a wire in the bar and flash it to the pos terminal on the battery. You will see either your turns/brake/running/reverse lights switch on/light up in the bar.
If everythings good, then the bar is OK.
Hope this helps?
Al.
Old Dec 30, 2008 | 08:12 AM
BlueRam2006
Yes, the key was on and the normal reverse lights were turned on.
I will give that a try abarmby at least I can rule out whether it is the bar or not.
Thanks for all the replies
Old Dec 30, 2008 | 10:55 AM
dirtydog's Avatar
dirtydog
Moderate User
If I had to guess, you used a quick splice t-tap. Sometimes they can cause issue's if you use a 16-14ga tap for an 18ga wire and vice versus can cut the wires. You should have used a blue tap. Red ones are for smaller wires. Yellow is for larger wires.
