Max Tire size on a 2wd with 2 in level?
Old Dec 29, 2008 | 01:16 PM
phlblouch's Avatar
phlblouch
Default Max Tire size on a 2wd with 2 in level?
ok, i need some help here. could anyone tell me this... i have an 08 quad cab 2wd and i want to level the front in order to put some bigger off road tires on it.
what is the max tire size i can fit? btw, i want to keep 20in rims.
also, Pics of your 2wd with this set up would be awesome!
Thanks in advance,
Phil
Old Dec 29, 2008 | 05:45 PM
Shandy's Avatar
Shandy
Let me know if you magically find a 2" lift kit for your 2wd 08...
Old Dec 29, 2008 | 07:33 PM
Shandy's Avatar
Shandy
Instead of starting a new thread... I'll ask this question here:
Since the '08 2WD's only option for a leveling kit is 1.5", will that allow a 35" tire? Please someone tell me yes.
Old Dec 29, 2008 | 08:26 PM
dodge it then ram it's Avatar
35 will be really tight. Almost no room to flex. You may be able to though. Somebody on here has 35's with a 2.5" leveling kit.
Old Dec 29, 2008 | 08:31 PM
HammerZ71's Avatar
HammerZ71
Not with the stock wheels, no backspacing. You need at least 4.25" backspacing to clear 35s with only a level. You'll have issues turning tight with the stock rims. Unless you get some skinny tires and I think that would look like doo-doo.
Also, there is not much room to flex, so speed bumps may even be an issue, regardless of the wheels...
Old Dec 29, 2008 | 08:49 PM
CreativeOffroad's Avatar
CreativeOffroad
Not too sure on what the max tire size is but I only have a leveling kit on my 2wd and I'm running 285's on it w/ 18" wheels and I think it looks pretty good. Here's a pic so you can get an idea of how it looks.
Good luck deciding!
Old Dec 30, 2008 | 12:15 AM
mdram43's Avatar
mdram43
i've got 285/75-17's on my truck (33's) and theres still like 2 inches left between the tire and fender on the side
Old Dec 30, 2008 | 12:21 AM
dirtydog's Avatar
dirtydog
Moderate User
But you have aftermarket wheels!
Also, it appears that your wheels have extra backspacing as they appear to stick out a bit further than stock.
Hammer said doo-doo....lmao
Old Dec 30, 2008 | 12:34 AM
mdram43's Avatar
mdram43
that would be less backspacing. im sure he has spacers on it.
Old Dec 30, 2008 | 10:43 AM
phlblouch's Avatar
phlblouch
yeah, from what i understand someone on here has 35x12.5x20's with a 2.5" leveling kit in front and 1 inch block in the back... I think this is what i get from reading multiple threads.. can anyone verify that this setup is do-able?
