Hemi Motor
You guys are both right in this situation. Yes, the engine does start to drop off in power as you go past about 5500 rpm's or so. There are lots of dyno sheets around that back this fact up. And at the same time, yes the trucks do run faster times with the shift points raised higher. There are plety of people who have experimented with shift points and had the same results. The thing that needs to be considered is that when the truck is at say 6000 rpm's, the amount of horsepower the engine is producing is still greater than what it produces at the rpm it will be at when the truck shifts to the next gear. This is why the truck runs faster when you raise the shift points to higher levels.
Hammer thanks for the info. That helps alot. I know that on my 350 tpi it would fall on its face close to 6000 rpms but my hemi does not show any signs of falling on its face. sever u are right about the motor was just typing. lxman i don't see how it will slow me down other than having the shifts being to high and not shifting quick enough. i have seen several vids on here and u tube that showed shifts at 6000 and they didn't seem like the motors were dying off any. could be the simple fact that u can feel when it falls on its face and not see it sometimes.
When it comes to acceleration, there will still be more torque to the wheels in a lower gear, even if the motor is past its peak torque. More torque to the wheels = better acceleration. A good trans/axle setup will allow you to shift at redline and land right in the torque band in the next gear.
Say a Hemi makes 375lb-ft max at the crank, and only 250 by the time it's wound out to 6,000. Coming out of 1st at redline with 3.92 gears, you're still putting (theoretically, of course it's much lower) 2900+ lb-ft to the axle. Peak torque in 2nd will only put 2300 lb-ft to the axle.
For fastest times, let the engine rev as high as possible in every gear. The engine loses 45% of it's mechanical advantage from 1st to 2nd, and 67% from 2nd to 3rd in a 45RFE trans.
It all depends on what you are driving. The gearing also has allot to do with how a vehicle will run at different shift points. In some cases you get better results by shifting further past the peak because it puts the engine at a better rpm when it does shift. It seems like my truck STOCK would benefit from a couple of 100 more rpm because it seems a few hundred rpm short of really being in its "powerband" when it shifts.
I've done the same test except I did it in my Ram. The quickest times were always with the shift points maxed out. While the lower shifts may have gotten you quicker times in your mustang, it doesn't necessarily mean it will do the same for a Ram.
