Does anyone have one of these?
Old Jan 3, 2009 | 02:47 AM
Stellar_D's Avatar
Stellar_D
Default Does anyone have one of these?
http://cgi.ebay.com/ebaymotors/06-07...Q5fAccessories
seems cheap, anyone have one or know of someone having one?
Old Jan 3, 2009 | 03:03 AM
lxman1's Avatar
lxman1
Site Moderator
You're better off with a black plastic one. Chrome gets too hot under the hood.
Airaid makes a cheaper set-up with the tubing and reuses the stock box with a better filter.
Old Jan 3, 2009 | 11:40 AM
TRXHemi's Avatar
TRXHemi
I have one similar and no, it does not that hot......
Old Jan 3, 2009 | 12:45 PM
dirtydog's Avatar
dirtydog
Moderate User
I like the plastic, it won't peel, rust and has no upkeep to really keep clean.
Old Jan 3, 2009 | 03:13 PM
lxman1's Avatar
lxman1
Site Moderator
You have to watch alot of the cheapies, the chrome on the insides will peel off and go into the engine. Make sure that the chrome is not on the inside. I have also heard of them rusting internally and flaking off as well. This is why the factory always uses plastic.
Check your tube after a long drive Greg about 15 minutes after shutting off the truck and see how hot it is. Heat soak is what will get ya. If you stop for a bit then leave again, the tubing will be much hotter, I would think.
Is that worded ok for ya Dog????
Old Jan 3, 2009 | 04:01 PM
jakp5's Avatar
jakp5
I've got that exact intake. It looks cool in the engine and wasn't too expensive. I put it in about a month ago and I havn't had any problems with it yet. Although, I haven't checked the inside of it yet.
Old Jan 3, 2009 | 04:49 PM
bwhite757's Avatar
bwhite757
Had one on my truck, that exact item.
However, even though I made damn sure that all of my fittings were tight and secure, the filter somehow managed to work it's way loose, and fell off somewhere on a 700 mile road trip....
Had to find a replacement filter, ended up with this:
I then got a seperate oil breather filter, and plugged the breather hole on the intake b/c I didn't like the way it looked.
Later I ended up putting the stock intake back on with K&N filter, mainly b/c I saw no significant gain from the setup...
Old Jan 3, 2009 | 05:46 PM
lxman1's Avatar
lxman1
Site Moderator
Yeah, that's why I recommend the Airiad MIT pipe and drop-in K&N filter. The HemiHat is the only real restriction in the system.
I only use the K&N because it last forever. I've had one in my Mustang for over 150K miles.
That kit looks like it puts the open filter close to the ground where it could get flooded in a big puddle and hydrolock the engine!!
The K&N kit advertised at AutoAnything claims a whopping 8hp increase on the 08 Hemi RAM. Not worth the $300 to me!
Old Jan 3, 2009 | 05:54 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
That exact thing happens to a lot of people with kits like this. Not exactly sure why but it is quite common.
Old Jan 3, 2009 | 06:22 PM
lxman1's Avatar
lxman1
Site Moderator
Gravity is not always your friend
Probably some harmonics down at the end of the long pipe causing the clamps to loosen over time.
