problem found ... (with pics)
Old Jan 4, 2009 | 03:48 PM
  #21
robeeto's Avatar
robeeto
Originally Posted by dirtydog
By asking this question, you should not even try to attempt to change your carrier yourself. You need special tools to even complete the job and looking at the pic says it all.
It's an open carrier, One wheel peel jobber!
'Doh!
Old Jan 4, 2009 | 05:36 PM
  #22
lxman1's Avatar
lxman1
Site Moderator
Did you drive with the parking brake on or something? They should have little wear unless they have been dragging!
Old Jan 4, 2009 | 06:32 PM
  #23
SmokeySportRam's Avatar
SmokeySportRam
as you should see from the pics, they never get used, thats why they are totally brittle dry and rusty, and why they broke. It looks like the the shoe pads rusted apart from the backing plate of the shoes.
they were new 6-7 years ago, then the iowa weather took its toll.
Old Jan 4, 2009 | 06:51 PM
  #24
TheForce55555's Avatar
TheForce55555
That doesnt look like a 2 wheel peel to me, but whatever you say man
Old Jan 4, 2009 | 06:52 PM
  #25
Ilovemytruck's Avatar
Ilovemytruck
good write up smokey. I had the truck at the dealer and they took off the rubber filler cap on the diff. They broke the yellow paint line my other dealer left on their when they serviced it for the diff fluid change. I saw some fluid leaking out and the paint line was broken and wanted to make sure they put enough in, dont even ask me why they were fuc*king with it they had no reason to be down there unless trying to sabatage something. How do I know how much Im supposed to have in it? Should I replace the rubber seal to be on the safe side?
Thanks for the sensor info too man it took about 24 minutes and I saved a couple hundred, you are the man!
Old Jan 4, 2009 | 08:22 PM
  #26
Ben D.'s Avatar
Ben D.
Originally Posted by JoeHemi
My gravel driveway is all I have to work with...but yea, I think a shop is the best "mod" someone can do for their truck!
here's to the gravel driveway lol
Old Jan 4, 2009 | 08:33 PM
  #27
TheForce55555
You guys ever heard of cardboard? makes and excellent creeper on gravel and when your done, just throw it away
I have a shop but it has too much other SH*T in it right now
Old Jan 4, 2009 | 09:02 PM
  #28
SmokeySportRam
where do you people think the clutch packs are. Go ahead blurt it out, Cause I know you cant see them in the pics, but I sure as hell did when I was inspecting it.
why else could I leave a posi burnout?
Old Jan 4, 2009 | 09:05 PM
  #29
SmokeySportRam
Did you have them do anything? Oil change or otherwise? I know anytime I do an oil change I inspect diff fluid.
No problem on the sensor info, glad it helped.
Old Jan 5, 2009 | 12:20 PM
  #30
Ilovemytruck
I went to autozone and put in about 1/3 of the 1 quart 75w 140 mobil 1 diff fluid. I was pretty low considering it only takes about 2.65 quarts or something. They were hooking it up to a starscan to pull a code for diagnostic, but I dont know why they would even mess with it? I filled it up till it came up to the rubber opening. Is that right?
