powersteering clamp pics please
Old Jan 7, 2009 | 10:39 PM
  #21
ray97's Avatar
ray97
Mine had the leak also. Put the clamp on and that stopped the leak for a few days. Then it started again....took the clamp and hose off, cleaned everything up and reattached the hose with the clamp and it has not leaked a drop since.
Old Jan 12, 2009 | 02:48 PM
  #22
Grey-Ghost's Avatar
Grey-Ghost
well the day after i put it on it didn't leak so time will tell
Old Feb 5, 2009 | 08:20 PM
  #23
travis_stl's Avatar
travis_stl
I discovered a leak on my 02 4x4 and after crawling under the truck looks to be the same thing. OSUFANS.. Nice picture to show how you placed the new clamp. So, while I was under the truck, I found it difficult getting one had around the hose to inspect. Any tricks to how you got both hands in to add the new clamp? If I take off the hose to clean like Ray97..do I need to bleed the power steering? Any other hints?
Old Feb 5, 2009 | 10:43 PM
  #24
Redone4x4's Avatar
Redone4x4
I undid the clamp all the way, put around the hose, and tightened it up. mine is lifted, i was able to sit under there between the bumper and radiator and reach up. had to really crank down the hose clamp though. oh, I degreased everything first though. its been two weeks since i did it, it only took about 5 minutes and the leak is gone now.
Old Feb 5, 2009 | 11:16 PM
  #25
ried69's Avatar
ried69
To get mine on since it wasn't lifted, I got up in there, and put my hand on the hose with the clamp opened up. As it was then hard, I layed down and tried to look at the clamp. Being hard to reach, you just have to find a way to get the other hand in there to tighten up the clamp and then you can maneuver yourself in there to however you can see it best. It's a real awkward place to get in and put that clamp on.
Old Feb 6, 2009 | 07:25 AM
  #26
Off_Road_Teacher's Avatar
Off_Road_Teacher
I did the clamp fix on mine earlier this week and it hasn't leaked yet. So far so good
Old Feb 8, 2009 | 03:47 AM
  #27
Grey-Ghost's Avatar
Grey-Ghost
I glad this is helping everyone else and letting people know about a cheap fix to something at is annoying as hell to deal with.
Old Feb 8, 2009 | 07:59 AM
  #28
Redone4x4's Avatar
Redone4x4
it sure helped me, thanks for starting this thread. the dealer wanted $251 to replace the hoses when my truck was in for some warranty work. I had the clamp already, so it cost me nothing more than five minutes. the how-to's in this forum are awesome!
Old Mar 15, 2009 | 11:07 AM
  #29
ronbo1821's Avatar
ronbo1821
Default can't find the leak
I have the 2005 quad cab ram 1500 with 40k miles, 3 mos ago it was leaking radiator fluid so they replaced the radiator. Then it started leaking powersteering fluid so they relaced 2 of the hoses. I still have a leak and can't figure out where its coming from. i too have a small puddle on the driveway and when I look for the leak I see fluid on the boots and on the hoses and on the bottom of the engine etc. I'm mechanically inclined but I'm not very familiar with this.
can someone make any suggestions?
Old Mar 15, 2009 | 11:30 AM
  #30
talon6's Avatar
talon6
did you look at the hoses like in the pic? cause i also had to add a clamp to that upper hose. hmmmm never seen this thread before. common problem it seems.
