removing overload leaf spring safe?
Old Jan 11, 2009 | 05:13 PM
dabig47's Avatar
dabig47
Default removing overload leaf spring safe?
i recently installed a claimed 2 1/2 inch drop schakles to level my 04 ram and its still a little bit higher...i was wondering if it will lower any if i remove the bottom spring overload one and wat would be the diff in the ride
Old Jan 11, 2009 | 07:06 PM
we_the_unforgiven's Avatar
we_the_unforgiven
Are you talking about just removing one leaf?
Old Jan 11, 2009 | 09:05 PM
Rojhan's Avatar
Rojhan
In theory, the overload won't kick in until you have enough load to engage it. If you look at it, it should only be touching the rest of the spring pack at the axle (until load is put on it). So, your ride shouldn't be affected with it out.
Old Jan 11, 2009 | 09:09 PM
RaiderJay6's Avatar
RaiderJay6
No issue in ride quality.
Old Jan 11, 2009 | 11:02 PM
froto'sride's Avatar
froto'sride
It would lower it but only the thickness of the spring. I was thinking about taking one out as well so if you do deside to do it measure if first and then measure it after and tell us what you came up with.
Old Jan 11, 2009 | 11:28 PM
dabig47's Avatar
dabig47
i will do this thursday when i get my truck back from the dealership i took it in b4 my warrantee is expired to do trans. and rear end work..
but yea i will do it and tell ya how low it went . thanx for the input
Old Jan 11, 2009 | 11:48 PM
badblackram06's Avatar
badblackram06
Yes it is safe. does not effect handling. you just wont be able to carry a heavy load with out it squatting. But I took the overload out of my 06 ram about a month before i decided to do a flip kit. Removing the overload only lowered it a half of an inch which is around the thickness of the spring. Those shackles are not worth the money if you ask me. If it was the really short shackle style then i think they only lower the truck 1.5 inches. The only thing they are good for is lowering the truck to a total of 6 inches after you do a flip kit. hope i helped
Old Jan 13, 2009 | 12:00 AM
dabig47's Avatar
dabig47
so by removing it should be leveled right?
Old Jan 19, 2009 | 10:48 PM
badblackram06
no it will still sit up higher in the back. it will only lower it about a half of an inch. to get it level you will need at least 2 inches or more i believe.
