Lamp Out/Dinging Problem
Old Jan 12, 2009 | 09:46 AM
BayouBill's Avatar
BayouBill
Default Lamp Out/Dinging Problem
I posted last week about my Lamp Out problem. Well, I thought I had the problem solved when I replaced the dome light -- WRONG. I thought it was kind of strange that a little dome light bulb would make my dashboard go off like World War III. Well, i was right.
This weekend the problem started again. On my way to work this morning, I drove without my front lights on. I turned on my front lights and bingo, the lamp out came on. Turned the front lights off, lamp out goes off. I did this over and over.
Someone on this forum said that this is a big problem with 3rd generations. Is there a permanent fix to this problem?
Old Jan 12, 2009 | 09:08 PM
SmokeySportRam's Avatar
SmokeySportRam
did you check all of your lights?
Old Jan 12, 2009 | 09:11 PM
draco8494's Avatar
draco8494
yeah possibly its just one of your fog lights out? i know my truck was doing it and i thought it was the tag lights..there werent working but everything els was with the lights on, but i was wrong it was one of my brake lights....prob solved
Old Mar 10, 2009 | 07:18 PM
Rudiger528's Avatar
Rudiger528
Default lamp out light
Bayou Bill,
I have an 05 ram my lamp out light was doing the same thing, however it only happens when i have my left turn signal on when im braking at the same time. I already replaced the bulbs so i fugure its got to be a short in the wiring somewhere, my next step will be to replace the panel that holds the reverse brake and turn light. ket me know if this helps.
Old Mar 10, 2009 | 08:01 PM
Pyro's Avatar
Pyro
I Beat Tetris
My "Lamp Out" indicator was playing the on/off game for five months before a taillight finally went out. Started doing it again and I found the connector to the taillight strip wasn't seated properly. Check for any loose connections or a short. Also check the license plate illuminators, if one of those is out it will trigger the lamp out warning.
Old Mar 10, 2009 | 08:39 PM
Ridinhigh's Avatar
Ridinhigh
Mine is going off but I have a brake light out on the right side just havent picked up the bulb yet
Old Mar 10, 2009 | 09:02 PM
04-fourseven's Avatar
04-fourseven
I chased that problem for about a month on my truck, and finally got sick of it. I went down and bought new headlights, which was a plus, and a can of electra clean and grease. Spent most the afternoon cleaning and greasing all my exterior bulbs. has been working fine for months now, knock on wood. man why did i tell that story? Now its going ding tonight, man im an idiot!
Old Mar 10, 2009 | 10:15 PM
Parts/Service's Avatar
Parts/Service
Replace the tail light strips and this problem will go away, This is a common issue with 3rd gens...
Old Mar 10, 2009 | 11:10 PM
Ridinhigh's Avatar
Ridinhigh
Hey do you know the part number for a right rear brake light bulb and the license plate light by chance
