Radar Detector direct wire
Old Jan 14, 2009 | 03:48 AM
  #21
dedogg's Avatar
dedogg
Originally Posted by lxman1
Do you have the auto dimming mirror? I wired mine into the plug on the back. Only powered with key on.
I now have t tint strip across the windshield, so it can not bee seen from outside.
I like the way you did that. No power problems? I am thinking thats the way I am gonna go. Do you have a DIY?
Old Jan 15, 2009 | 12:04 PM
  #22
04-fourseven's Avatar
04-fourseven
i have a beltronics 995, and i would like t do this with my 2004. however im not really sure what kind of plug is on the end of that cord. Obviously im not talking about the end that plugs into the detector, but the other end. I would like to know, so i could make one form scratch. 5-10 dollars its sounding like?
Thanks guys
PS, newbie here, first post, learning a lot from the site!
Old Jan 15, 2009 | 07:28 PM
  #23
lxman1's Avatar
lxman1
Site Moderator
I bought a set of wire ends at Radio Shack that are crimp on and have a small diameter pin that will stick into the mirror plug. I know the pink one is the key on only +, I would have to look at it again to see which is the -. I'll look tomorrow. It's too cold to go out tonight . I'll get the part number on the terminals too. The bag is in the garage. It was a pack of 10 for about $2 % red, 5 black.
I like it being up out of the way and not noticable from outside. I'll try to get some more picture tomorrow.
Old Jan 15, 2009 | 11:39 PM
  #24
TRXHemi's Avatar
TRXHemi
Well I have the new Cobra but it came with a coil cord, so I will have to get a straight power cord before I wire it directly. I don't want to cut up the coil cord in case I need to use it in my wife's truck.
Old Jan 16, 2009 | 06:39 PM
  #25
lxman1's Avatar
lxman1
Site Moderator
OK, the connectors are actually red and blue. I used red for hot and blue for ground. The + wire goes to the Pink wire in the bottom plug and the - goes to the black wire next to the pink.
I used RadioShack connectors part # 64-3095. They were about $1.99. Here are a couple of pictures.
Hard to see from the outside with my tint strip across the top of the windshield.
Old Jan 16, 2009 | 06:41 PM
  #26
devildg84's Avatar
devildg84
i ran mine from the lighter outlet in the dash
Old Jan 22, 2009 | 05:57 PM
  #27
Brandangd69's Avatar
Brandangd69
http://i248.photobucket.com/albums/g...Picture012.jpg
This is a picture of a Radar scanner that i harded wired in a dakota, For power i used the accesory (red) wire on the head unit as I installed them for him at the same time, By using the red wire instead of the constant (yellow) the dectector turns on and off when he turns the truck on and off
Old Jan 22, 2009 | 06:03 PM
  #28
dirtydog's Avatar
dirtydog
Moderate User
M45 Laser Blinder is the only way to go! I've got it on my Cobra.
However, I know several Sherriff's that use the plain ole radar signal and get many guys that have laser detectors. My Brother-in-law is a local and uses the radar most of the time. He only uses the laser for speed trap set-ups.
