Finally put my jet chip in!
wrote up a sweet fiy too.
https://dodgeforum.com/forum/diy-do-...p-install.html
but yea, it's snowing like all hell outside, and i got to top out at like 20mph while cruising around in a blizzard during rush hour traffic. but, the cars revs up a lot quicker, and it shifts soooo much better.
anyways, i'll be keeping u informed.
When I put my chip in it wouldn't snap in and I thought something was really screwed up. I tried to hook everything back up while it was still loose in the pcm and it didn't work. I ended up calling jet and the guy told me he was 6'2 260 and he had to get up on his tippy toes to get the o-ring on the chips to snap in. He also said it helps to pull that little tab on the back up when pushing it in there. I pushed it so hard that I had a rectangle imprinted in my palm and it snapped in there. I don't think you are supposed to need a screwdriver to force it in, but as long as you didn't break anything.
yesterday i got to haul the roads with it...awesome. so much more power. and the shifting, it so good. it does just downshift as soon as u let off the gas....like when you['re cruising at 40 down the street, it will hold u in third, as opposed to dropping into the last gear - then if u wanna accelerate just a little more, the truck goes all ape**** and downshifts and makes a bunch of commotion to go like 2 more mph faster. know what i mean?
it's awesome.
BUT, i have a check engine light that came on this morning...and it's idles all stupid. i'm also not running a full tank of high octane. when i put it in, i had the cheap gas in there (half tank) and yesterday i topped it off with the good stuff...so, maybe after this tank runs out, i'll have all 93 octane gas in there.
it's awesome.
Trending Topics
yea, i called them up. he said if it worked one day, THEN i got the light, it's a connection problem. made sense (but honestly thought it was the bs answer). anyways, without even disconnecting battery, i went over to computer (while truck was off) and pressed all four of the harnesses back in...(they seemed to all be in, cause when i pushed, nothign "clicked" or anything...and yea, started truck back up and all is well.
