34Gal Fuel Tank & Cable Route
Old Jan 14, 2009 | 02:37 PM
Jeepsrock's Avatar
Jeepsrock
Arrow 34Gal Fuel Tank & Cable Route
Due to some problems recently, my gas tank was replaced on my 08 Ram 1500. I was taking a look at their work and noticed on the side of the tank there is a cable/hose running in split loom sheething that seems to be badly squished with no play or room (between tank and wall) fairly tight also.
Can anyone check to see if their Rams has the same thing or if maybe i need to loosen something to take care of this. If not i can get a picture later this evening.
Pete
Old Jan 14, 2009 | 05:00 PM
draco8494's Avatar
draco8494
wish i could help ya but i got a 04 2500 i dont think itll be the same...
Old Jan 14, 2009 | 09:01 PM
WhiteBerry's Avatar
WhiteBerry
if no one gets back ill have an answer after work tomorrow, hopefully 06 is the same
Old Jan 14, 2009 | 10:34 PM
Jeepsrock's Avatar
Jeepsrock
Here are some pics for easy comparison. Thanks for those who are helping.
The hose or cable i am referring to enters here at the tank. Looking from wheel well. It is very strained it seems.
The last few picture are as seen from below.
Thanks again.
Pete
Old Jan 15, 2009 | 03:50 PM
draco8494's Avatar
draco8494
definatly doesent look like its suppose to do that...., just looked at my truck and it has something like that but it has wire loom holders that hold it to the top of the frame and its not inbetween the frame and tank
Old Jan 15, 2009 | 04:41 PM
Jeepsrock's Avatar
Jeepsrock
Thanks Draco...I'm not sure, maybe it was changed in 08 ? It doesn't look right but given the holder locations i don't know how else it can be ran ?
Anyone here with other observations ?
Pete
Old Jan 15, 2009 | 04:54 PM
WhiteBerry's Avatar
WhiteBerry
just checked mine, i cant tell though because i have the wheel well covers so i cant see the first view that you have, i can only see from below and it looks the same from there... sorry!
Old Jan 16, 2009 | 01:12 AM
Jeepsrock's Avatar
Jeepsrock
WhiteBerry thanks for looking.
Are you saying the the area visible from the bottom (the area between the tank and frame) is similar on your truck ?
Pete
Old Jan 16, 2009 | 06:33 PM
WhiteBerry's Avatar
WhiteBerry
yea, i can see those wires and such, they dont look pinched or anything on mine
Old Jan 16, 2009 | 08:07 PM
lxman1's Avatar
lxman1
Site Moderator
Looks like the vapor recovery hose. If you are not getting a check engine light, it is probably not pinched, but I would take it back and have it redone. Over time it caold cause problems. I don't recall seeing that on my 08. Mine is only 26 gal.
