lights behind grill ? opinions please
I bought the Hella 500 and upgraded to 100watt bulbs, but if you do so, you cannot just put in different bulbs without upgrading the thin wiring that comes with them. Harbor Freight sells a 9" Stainless HID light assembly with housing and bulb. They are individual and run $120 each. They don't come with any wiring.
the 500ff is the same size as the 500. only difference between the 500ff and the 500 is the lens. on the 500ff the lens is clear, the lens on the 500 is ribbed/cloudy. check out all the different light hell offers here
www.myhellalights.com
at idle there is little difference on the guage when i turn everything on. i run with the stock alternator and single stock battery.
also the KCs cost just over $100 a pair with wiring,switch, and relay for the 100W.
if you want to upgrade the bulb they are really easy to change and you dont have to change any wiring.
6 hemi ram, everytime I see your truck, I always think it's a semi at first. That one really looks awesome.
i am also seeing a hella 1900 that is nearly identical to the KC 6" with 100W bulb, i assume an H3,for $26 apiece. think i might get me a set for the Rubicon.....or maybe 2 i need another set for the top of the Ram. as per the question about pics for the mount of the lights, here are a few. also i did not make this one but have been rolling around the idea of making some. thanks for the request.
![Name: Picture029.jpg
Size: 18.5 KB](https://dodgeforum.com/forum/attachments/3rd-gen-ram-tech/112117d1501428396-lights-behind-grill-opinions-please-picture029.jpg)
![](http://i274.photobucket.com/albums/jj254/bravada94/Picture027.jpg)
![Name: Picture025.jpg
Size: 16.8 KB](https://dodgeforum.com/forum/attachments/3rd-gen-ram-tech/112118d1501428396-lights-behind-grill-opinions-please-picture025.jpg)
![Name: Picture007.jpg
Size: 21.5 KB](https://dodgeforum.com/forum/attachments/3rd-gen-ram-tech/112119d1501428396-lights-behind-grill-opinions-please-picture007.jpg)
