electronic door locking motor
Old Jan 18, 2009 | 08:13 AM
02Steve1990's Avatar
02Steve1990
Default electronic door locking motor
Whats up guys, due to the recent cold weather, I noticed that after the first really cold night a couple days ago when I went to start up the truck i noticed that when I unlock the doors the passenger side lock makes a buzzing sound for about 1 second as the lock goes up whe I unlocked it. I talked to my buddy at work who owns a durango and he said he had the same problem and needed to replace the locking motor by taking off the door panels, is this the only way to fix it, do any of you think it will stop once it gets a bit warmer out or should I just go and replace it, and if so, how much should it cost to buy a new locking motor?
Old Jan 18, 2009 | 08:55 AM
dirtydog's Avatar
dirtydog
Moderate User
I haven't actually peeked inthe door panel enough to notice how everything is buttoned up, however if the linkage is catching on something that could cause the motor to over work itself. If you can move the lock up down the same on both sides with your fingers then you need to replace the motor as stated.
Old Jan 18, 2009 | 09:35 AM
02Steve1990
When I pull the lock up with my hand it doesn't make the noise that it does when I use the automatic unlock button
Old Jan 18, 2009 | 10:37 AM
dirtydog's Avatar
dirtydog
Moderate User
Sounds like you do indeed have an actuator problem
Old Jan 18, 2009 | 10:52 AM
jobguy's Avatar
jobguy
Default Cannot unlock door
The electric door lock made a ratcheting/grinding sound a few times and stopped working. I cannot unlock the door at all (neither the door handle nor the lock button will move). Any suggestions?
Old Jan 18, 2009 | 11:11 AM
02Steve1990
you and me probably both gotta go to a Dodge dealership and see if they have another door locking motor that we can replace our current ones with, I'm sure mine will stop working soon too
