Is 4wheelsparts.com correct?
Old Jan 20, 2009 | 02:48 PM
caliboy@heart's Avatar
caliboy@heart
Default Is 4wheelsparts.com correct?
I just called them and they said that the biggest I can go without cutting and rubbing on my 04 4x4 Ram is a 295/70/17 in the nitto terra grapplers. is this correct?
Old Jan 20, 2009 | 02:55 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
yup. they're pretty much right. that's a 33" tire. put a leveling kit on the front end and you'll be able to go to a 35" tire.
HammerZ71's Avatar
HammerZ71
You can to about a 33"x12.5" tire, but with the stock wheels, which do not offer a decent backspacing, you may rub a bit at extreme full turn.
The Nito's above are roughly 33.3" x 11.6", so unless they offer a tire of that height that's just a hair wider, I'd say it's an accurate assessment...
Old Jan 20, 2009 | 02:57 PM
nickahern1's Avatar
nickahern1
yeah biggest you can fit without a leveling kit is a 33x12.5 on a 02-05 ram. grab a leveling kit or crank those t-bars( for free ) and you can go up to 35x12.5....
Old Jan 20, 2009 | 02:58 PM
nickahern1's Avatar
nickahern1
damn im stoo slow at typing hammer alsways beats me.
TANKZ400's Avatar
TANKZ400
The 12.5 is what you cant fit with out spacers.
Old Jan 20, 2009 | 03:01 PM
nickahern1's Avatar
nickahern1
??? what tank? 12.5 is what you CANT fit without spacers? on the 06+ you need spacers to fit 12.5s because of the coil over suspension but on a 02-05 you can fit 12.5 a little better ( spacers would provide more room though)
Old Jan 20, 2009 | 03:02 PM
HammerZ71's Avatar
HammerZ71
With the torsion bar '02-'05 you can get away with the 12.5" width on the stockers without spacers. Maybe a hair of a scrub but only at extreme full turn. You'd be dead on though for your truck. The '06+ coil overs seem to have a bit less clearance where the a-arms are concerned and I'd not do the 12.5s without spacers or a sufficiently backspaced aftermarket wheel...
Old Jan 20, 2009 | 03:08 PM
caliboy@heart
sorry all, the guy at 4wheelparts.com said "with a leveling kit" i still would only be able to go with 295's, with or without the stock wheels and with or without spacers. so, he is innacurate then?
Old Jan 20, 2009 | 03:13 PM
nickahern1's Avatar
nickahern1
with leveling kit you can go to a 35x12.5. so yes he is innaccurate. with a spacer they will fit even better but they will fit and if they rub they will only do so at absolute full turn without spacers.
