Ok dumb ?
Old Feb 20, 2005 | 07:55 AM
Red Ram Hemi 2005's Avatar
Red Ram Hemi 2005
Default Ok dumb ?
Will this work on my 05 and will it void warranty?
http://www.super-chip.com/chips/inde...=item3714.html
Old Feb 20, 2005 | 10:51 AM
moparturd's Avatar
moparturd
Default RE: Ok dumb ?
They are year specific. They should be coming out with one before too long for the 04-05 Hemi.
Old Feb 20, 2005 | 12:23 PM
Red Ram Hemi 2005
Thx for the reply mopartodd, but does it viod the warranty? if done on your own that is.
Old Feb 20, 2005 | 12:31 PM
Red Ram Hemi 2005
Oh yeah, the 04 and 05 are the same truck I think? the only differance is the dodge emblem on the tailgate if I'm not mistaken?
Old Feb 20, 2005 | 01:06 PM
gilitar's Avatar
gilitar
ORIGINAL: Red Ram Hemi 2005
No, there are differences in the cpu from 03 to 04. This one will not work on an 04 or 05.
Old Feb 21, 2005 | 11:56 AM
Red Ram Hemi 2005
I was talking about the 04 and 05, not the 03. How about the warranty?
Old Feb 22, 2005 | 12:15 AM
jmr0360's Avatar
jmr0360
Do NOT use the Superchips Model 3714 or 3715 (newest version) on any vehicle for which it is not designed. Every new model year contains different program instructions (FLASH ROM). Writing a new program to ROM (in the wrong vehicle) could leave a vehicle non-running. Wait until Superchips has a model specifically for your year. Use of programmer does not void warranty, however if you ever take the vehicle in for service, you should restore the "stock" program because very often there are FLASH ROM updates to your vehicle and if the dealer rewrites your "modified" program, the vehicle again could be rendered non-running. The Superchips programmer will do this for you. John
Old Feb 22, 2005 | 12:31 AM
gamagatsu1's Avatar
gamagatsu1
heres my ?? what kind off truck are they testing when Superchips dynos the truck? is it stock or does it have a peformance exhaust and cold air induction? it claims 30 horsepower gain, are those results for certian controled conditions such as outside air temp. i have always heard that "chiping" a normally aspirated engine won't do as much as most program manufactures advertise. hope i make my self clear in what im asking and saying?
adam
Old Feb 22, 2005 | 01:41 PM
Silver Eagle's Avatar
Silver Eagle
Is this something that has to be plugged in all the time or can you set it up then remove it...
Old Feb 23, 2005 | 02:13 AM
jmr0360's Avatar
jmr0360
This message is for anyone. The Superchips TriTuner is a hand held device that plugs into the diagnostic port under the steering wheel. It plugs in via a cable similar to a computer serial data cable. You simply plug it in and follow the instructions, then you remove the Programmer. Your done. You keep the programmer in your garage or wherever until you want to restore the stock program or change to one of the other programs (there are 3). This handheld programmer can also check diagnostic codes (if for instance you get the CHECK ENGINE lamp)-you can then check what the problem is. You can also CLEAR the codes. As for what they test these on, they are for STOCK ENGINES ONLY. If you have modified the air intake/exhaust etc, this programmer is not for you. Since all 1500/2500/3500 can have different power trains/GVWR, Superchips engineers the program for basically each vehicle (For example a 1500 2WD would not have the same program as a 2500 4WD. The programmer can tell what you have by your VIN#, it then loads the appropriate program. As far as their power gains, absolutely they are done under certain conditions and we have to use our own judgement wheter the cost justifies the gains. In my case, my problem was that I tow a large 5th wheel and I did not like the way the auto-transmission shifted. Since all of the shifting is controlled electronically (via the program) not much I could do. However, now that the tuner came along, I bought one, took a chance is more like it! However, it has improved the feeling of the transmission under heavy tow loads. So, in my case, it was worth the money. As for HP/TORQUE gains, Hard to say. It feels a bit more responsive, but you have to ask yourself if "a little more" is worth $400.
Have fun!!
