Thermostat Replacement: Afternoon job or Weekend terror?
Theres no gasket to scrape away in an 03 Hemi.
There's a metal thermostat with a rubber ring around the outside of the Tstat.
The rubber ring is the gasket.
When you re-assemble, make sure you seat the Tstat in the housing the correct way and don't "pinch" the rubber gasket when tightening it all up.
An hour tops, should see you done.
Al.
Al.
