4x4 Concern
Old Jan 29, 2009 | 11:25 AM
Hoeter's Avatar
Hoeter
Default 4x4 Concern
Hello all...I have a 2007 1500 4x4 with the 4.7L engine. Went to dig out this morning from the massive snow/ice that we received here in Cincinnati and I am concerned about the operation of my transfer case and 4X4 system.
1. I shift into 4 LOCK...works perfectly fine. I hear the front and rear axles join together and the 4WD light on the dash quits flashing.
2. I then shift into 4 LOW...and in addition to the 4WD light being illuminated, 4 LOW will not quit flashing. Is it supposed to keep flashing or is there a problem that I will need to have repaired under warranty?
BTW, I still have the factory warranty and my shifter is on the dash near the steering wheel.
Any help would be appreciated. Thanks a bunch.
Old Jan 29, 2009 | 11:29 AM
SeMiGoD's Avatar
SeMiGoD
I put my truck in neutral when i engage 4 low. It takes a few seconds to hook up, give that a shot.
Old Jan 29, 2009 | 11:43 AM
Hoeter's Avatar
Hoeter
I gave that a shot, and it worked perfectly. Thanks man!
Old Jan 29, 2009 | 12:08 PM
SeMiGoD's Avatar
SeMiGoD
Good deal, glad it worked and theres nothing wrong with your ride.
Old Jan 29, 2009 | 03:30 PM
V_Scapes's Avatar
V_Scapes
yea you always have to put it into nuetral when you want to get in and out of 4lo
Old Jan 29, 2009 | 03:41 PM
Jordan5.7's Avatar
Jordan5.7
You mean someone actually has a 4wd light that works?
dirtydog's Avatar
dirtydog
Moderate User
Nuetral is the best bet. Sometimes getting out of 4lo can be a PIA as well. If this happens, simply shift the truck into reverse and then back into drive and it should fix the problem. Also, sometimes when disengaging, the truck may need to be driven 15ft slowly before it will disengage.
4hi, 2hi can be shifted into anytime below 55mph.
Old Jan 29, 2009 | 04:10 PM
V_Scapes's Avatar
V_Scapes
i usually slow way down or stop when i shift in and out of and 4x4, just to be cautious.
