you lot have scared me
Old Feb 9, 2009 | 02:12 PM
osufans's Avatar
osufans
Haha, I was about to jump on that one too dirtydog, but I figured I'd let someone else get burnt first.
I was thinking the same thing...actually in reverse. If he is getting 18.5 MPG on Imp Gal, then it would be lower in US Gal. However I think he is stating the on-board reading is showing 18.5 MPG US Gal, which would be something like the 22 MPG Imp Gal he calculated. Anyone else confused?
Old Feb 9, 2009 | 02:26 PM
Redone4x4's Avatar
Redone4x4
makes sense to me. truck reads us gallons, he calculated imperial gallons. So he got more miles per his "gallon" that he purchased, I think is what he's trying to say. I could be wrong though...
Old Feb 17, 2009 | 02:36 PM
Mr Furyous's Avatar
Mr Furyous
Default not so scared now
truck is great ran nearly 400miles mosly short journeys cant stop using truck fuel comp says 11.9 reckon that about 14.5 in our imperial gallons. stuck 5.30 semi syn and filter change and dropped a k&n panel filter in air box next jobs are to change diff oil trans fluid then to tackle plugs still unsure what plugs to use my parts supplier says stick with the champions but have been offerd autolite platignums wot do u think. rear 20" tyres will then need changing have got some general grabbers have any of u used them once again thanks for advice both to forum members in usa and uk
Old Feb 17, 2009 | 02:52 PM
HammerZ71's Avatar
HammerZ71
Good call on the oil, despite what was stated here, your '03 wants 5w/30. Stay with synthetics anywhere you replace fliuds.
For plugs, stay with the Champion coppers, they are cheaper and most actually report a degraded performance and fuel economy with the much more expensive platinum types. At recommended 30k changes and 16 plugs, your wallet will thank you anyway.
The use of synthetics all around (don't forget the additive in the rear if you have the factory LSD, and yes, I'd pour in at least half a bottle even if the synthetic you use states it's not needed), coupled with the better flowing K&N drop-in and a little better flowing cat-back exhaust will do quite nicely.
If I were going to do any modifications at all after that, I'd pick up a nice "canned tune" tuner such as the Superchips Flashpaq 3815 or Diablo Predator and call it a day. Many benefits to a tuner, better performance, mpg's, firmer transmissions shifts and the ability to read and clear codes. Personally, I think the firmer shifts with a Superchips is worth the cost of the unit alone...
Best of luck with your new investment...
Old Feb 17, 2009 | 04:24 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
+1, that's about all i'm using mine for right now.
Old Feb 17, 2009 | 05:51 PM
MikeHTally's Avatar
MikeHTally
Originally Posted by Mr Furyous
Hi rammers have been reading ur forum for months now and have take taken the plunge and am buying a 2003 crew cab hemi truck 26000 miles this weekend. However am expecting the 9.25 corperate 3.9 gears anti spin diff to explode any momment killing all bystanders. The valve springs to break smashing engine to bits. The front suspension to collapse etc Im from London uk but dont hold that against me have always been a mopar man have a 64 sport fury drag car So how can I check about my springs etc as dealers over here dont want to get involved. would really appreciate any help chassis number1D7HA1BD03F316901. Truck has been in UK since 2004 also am I right in believing the c clips arnt the problem it is the retaining clips in the lsd. thanks for all u reading this great forum cheers mr furyous
Don't forget your hair will fall out, and your dog will have puppies mysteriously. There's a rumor that the purchase will cause a shift in global warming and the earth's poles will shift. BTW, how did you find a six-year-old truck with only 26,000 miles? Mine is an '03 with 99K. When I opened the pumpkin at about 94K, the clips were solidly in place. The PO did have the front hubs changed, but so far it's been solid.
Old Feb 18, 2009 | 12:04 PM
Mr Furyous's Avatar
Mr Furyous
figure that when the trucks are imported to uk with fuel nearly $8 a uk gallon they dont do the miles that you do in the states my truck had been sat for 6 months and had only done 1000 miles in 18 months friend of mine just brought an 04 rumble bee with only 22000. anyone any thoughts on the general grabbers tires cant find anything on forum cheers
Old Feb 18, 2009 | 12:16 PM
metamorphosis's Avatar
metamorphosis
Ah, that'll be me then. 35k kms. Im coming over to Florida on the 7th March. Gonna get all as above Superchip and CAI and then fit a home made Dual on.
By the way mines better than his. lol.
