Looking for a compatible bedliner
Old Feb 6, 2009 | 07:08 PM
f41stryker's Avatar
f41stryker
Default Looking for a compatible bedliner
Hey guys I need help here. I'm looking for a bedliner for an 08 Ram Shortbed, thing is my truck has the Chrome Bed Rails, can anyone help a brotha out? Looking for something in $200-$300 price range if possible. I emailed moparpartsamerica and they said they have nothing that will work.
Old Feb 6, 2009 | 07:55 PM
raminator08's Avatar
raminator08
how about a spray on bedliner? your local truck accessory store could do it. thats what i have and it works fine for me. they are not all that exspensive
Old Feb 6, 2009 | 08:18 PM
Rojhan's Avatar
Rojhan
I think you could get a spray-in for the $200-$300 range. Maybe a little bit more. Having had plastic drop-ins, rubber mats, and the spray-in, the spray-in wins hands-down.
Remove the rails, get it sprayed, and put the rails back on.
Old Feb 6, 2009 | 08:21 PM
red06RAM's Avatar
red06RAM
A good spray on liner will cost well over $300. But there are a few DIY kits available. I think you could do that for under $100.
Old Feb 6, 2009 | 09:28 PM
Hoss356's Avatar
Hoss356
Not to be the advocate for saving money on here... but since they will sand down the paint in the bed anyway there is no rush if you decide to go with the spray in bed liner. Also the professionally sprayed liners work better then the DIY roll in's from Wally World or the parts store.
I say go with the spray in and in the mean time don't be afraid to use the bed as scratches will even make it easier on the poor bastard doing the sanding and prep work.
Old Feb 6, 2009 | 10:19 PM
f41stryker's Avatar
f41stryker
Is there no plastic liner out there or is there a problem with them?
Old Feb 6, 2009 | 10:35 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I would have to say the same as the othrs and recommend getting a spray in liner. Just save up a couple more hundred than you were already going to spend and get a liner professionally sprayed in.
Old Feb 6, 2009 | 10:36 PM
SilverBullet08's Avatar
SilverBullet08
i have a bedliner and it doesnt go on the sides the it wouldnt affect the bed rails
Old Feb 6, 2009 | 10:49 PM
sos's Avatar
sos
There are under-the rail style drop in plastic liners, but I'd go with the spray in as well. One problem with the plastic drop in liners is they scratch the bed from the vibrations, and trap moisture under them - causing the metal to rust. They are also much more slippery than the spray in liners. You can throw things in the bed and they stay put with a spray in. With a drop in, they slide around.
Old Feb 6, 2009 | 11:17 PM
raminator08
i saw one down here in texas for a very good price
http://www.southeasttexas.com/classi...0&type=general
its probably gone or a scam
