approximate gear oil quantities
Old Feb 9, 2009 | 10:28 AM
Ben D.'s Avatar
Ben D.
Default approximate gear oil quantities
Manual doesn't say how much for rear and front differentials is needed to fill em up. I realize it won't be exact but I'd like to know roughly so I order the right amount from mobil1. i know what weights and about the friction mod for the rear but that's all that is in my manual. checked faq's and DIY didn't see it.
Old Feb 9, 2009 | 11:38 AM
irelandshemi's Avatar
irelandshemi
dont know if this helps but someone posted this when i was inquiring about it
http://dodgeram.info/tech/BRSpecs/fluids/specs.html
Old Feb 9, 2009 | 11:53 AM
osufans's Avatar
osufans
I just did mine about a month ago, and I wanna say the front 205MM axle took just about 2 qts. The rear took 2.5 qts. You'll need 2 qts for the front and 3 for the back. They take different grades. From the spec sheet posted, which I believe to be correct, the front takes 70w-140, and the rear takes 80w-90, both synthetic.
Old Feb 9, 2009 | 12:21 PM
abarmby's Avatar
abarmby
Go here and find nost Ram manuals.
http://www.farmtalk.org/downloads/
Al.
Old Feb 9, 2009 | 12:43 PM
dirtydog's Avatar
dirtydog
Moderate User
I know the back requires Synthetic, but not sure if the front does. Regardless if it were me, I would just put in Synthetic. You only talking about an extra $25
Old Feb 9, 2009 | 12:53 PM
osufans's Avatar
osufans
I'd have to check the manual. I know I bought synthetic for both, and I'm pretty sure it called for it. Regardless, you're not saving much to make it worth not using.
Old Feb 9, 2009 | 08:22 PM
Ben D.'s Avatar
Ben D.
mine didn't say synthetic required but i'm doing it regardless the thought of not using synthetic never crossed the mind.
Old Feb 9, 2009 | 08:32 PM
TheForce55555's Avatar
TheForce55555
I put 2 quarts in the front and rear on my 3rd gen, The manual stated you should use 75-90 for the front diff and 75-140 for the rear diff
I bought three quarts for the rear, but now I have a full bottle of RP gear lube rolling around on the backseat
