aftermarket wheel question
Old Feb 9, 2009 | 02:56 PM
jwade2385's Avatar
jwade2385
Default aftermarket wheel question
Thinking about putting some after market rims on my inferno red 2007 dodge 2500. i'm looking at the american eagle 197's in chrome and black. The offset on the however is -11 and the rim is 9" wide instead of the factory 8". Anyone have any idea how much further they would stick out. i dont want something that would stick out to far? any help is greatly appreciated!!
Old Feb 9, 2009 | 03:07 PM
HammerZ71's Avatar
HammerZ71
what is the backspacing?
Old Feb 9, 2009 | 03:18 PM
jwade2385's Avatar
jwade2385
backspacing is 4 1/2 inches
Old Feb 9, 2009 | 03:30 PM
ramhunter9's Avatar
ramhunter9
and i thaught i was the only one that didnt get this eaither
dont worry hammer will fix ya up helped me.
Old Feb 9, 2009 | 03:42 PM
HammerZ71's Avatar
HammerZ71
your pm has been answered...
Old Feb 9, 2009 | 03:47 PM
osufans's Avatar
osufans
So if I understand correctly, a 9" rim at 0 offset will have 4.5" backspacing, correct? So a -11 offset would be ~ 4" backspacing. (4.5" - ~.5" (11mm/25.4=.43"))
I can never remember how that stuff works.
Old Feb 9, 2009 | 04:07 PM
BEAR's Avatar
BEAR
Here is a link to a site that helped me understand all that when I was looking for rims. By the way my rims have a 4" backspace. You can look at my photo gallery, there is some pics down the side of my truck and you can see how far mine stick out. Keep in mind I have fender flares that stick out 2.5".https://www.rsracing.com/tech-wheel.html#backspace
Old Feb 9, 2009 | 04:17 PM
osufans's Avatar
osufans
I agree with that site, but their quick reference guide contradicts with what they say. Center-line is the center of the rim, so in the case of a 9" wheel, that would be 4.5". So how does a rim with 0 offset have 5" of backspace?
Old Feb 9, 2009 | 04:30 PM
BEAR's Avatar
BEAR
Well if you noticed the centerline of the rim is measured from the OUTside edge of the rim whitch would make most 9" rims measure right at 10"s. The size measurment of a rim, such as 9" and 10" is measured from the inside of the lip of the rim where the tire meats the rim. I have a set of 10" rims that measure 11"s from outside edge to outside edge and, as I said, that is where they get the centerline from.
Old Feb 9, 2009 | 04:46 PM
osufans's Avatar
osufans
gotcha, now that makes more sense...so in reality you need to add about 1/2" per side to get full rim width. that makes the 4.5" backspacing just about right.
thanks!
