noob looking for help!!!
Old Feb 14, 2009 | 10:25 PM
mack10's Avatar
mack10
Default noob looking for help!!!
I have a 06 hemi 2wd I was looking to put on 35's and I know I need to get at least a 2 inch lift. I was wondering if i should go with a body lift or a suspension lift?. I was thinking of getting a 3 inch body lift but i'm unsure of the company to buy from and what brand. Thanks in advance
Mike
Old Feb 14, 2009 | 10:31 PM
AF_HEMI's Avatar
AF_HEMI
welcome to the forum. theres a great search function on here that allows you to search through previously talked about topics. this is one that has been hashed out like crazy.
For 2-3", a leveling kit is probably the most popular. A 2-3" suspension lift is kind of a waste of time. for a 3" lift, go with a body lift. Perfmormance Accessories makes a great kit for under $400. You're also more than likely going to need a 1.5-2" wheel spacer to get the stock wheels to hold 35's without rubbing. good luck
Old Feb 14, 2009 | 10:46 PM
mack10's Avatar
mack10
What is the advantages and disadvantages in getting the 2" leveling kit. I was going to go with a aftermarket wheel to avoid wheel spacer. Also, if i get the 2" leveling kit i can run 35" tires with no rub?
Old Feb 14, 2009 | 11:05 PM
SeMiGoD's Avatar
SeMiGoD
Personal Opinion: screw the level kit and look into a raised spindle. It wont change the geomotry of the suspension and end up much cleaner...just more expensive.
Old Feb 14, 2009 | 11:24 PM
AF_HEMI's Avatar
AF_HEMI
Or just got body lift and keep the stock suspension completely unchanged.
Old Feb 14, 2009 | 11:33 PM
raminator08's Avatar
raminator08
or get a 6" suspension lift
Old Feb 14, 2009 | 11:49 PM
mack10's Avatar
mack10
I'm just trying to get 17 inch wheels with 35 inch tires.
I figured i needed to get 2 inches from somewhere and I'm trying to figure the best way without spending to much money.
Old Feb 15, 2009 | 12:04 AM
raminator08
http://www.suspensionconnection.com/...09103-D2L.html
