need some help from the sound guys
Old Feb 15, 2009 | 11:52 AM
raminator08's Avatar
raminator08
Originally Posted by rssjib
You may or may not have speakers in the dash. If you have the Infinity upgraded stereo you will. Also, according to Crutchfield my 2008 model will handle 6.5" in the rear doors....check on line with them and it lets you know what size is good. Like Raminator said, they include all of the wiring adaptors, etc. Their prices aren't too bad when you factor all of that in. I bought my first amp from them back in 1988! LOL
i guess the 6-1/2" are just for the quad cabs. it said mine has the 5-1/4s
Old Feb 15, 2009 | 12:04 PM
chambers's Avatar
chambers
Originally Posted by lax
i don't know if this link will work but this is kinda what i have in mind for now
http://www.crutchfield.com/app/cart/default.aspx
if it does not work then this is what i have picked out
http://www.crutchfield.com/p_130P410...H-P4100UB.html
http://www.crutchfield.com/p_20607DS...r-07DS600.html
http://www.crutchfield.com/p_575P169...ate-P1694.html
and i don't need an amp to just run the door speakers right?
That should work and crutchfield will send you all the stuff needed for the install, including directions for how to take everything apart. I just got those 6x9's for my truck and they're great aside from the fact that I had to fab a mounting bracket b/c I threw my old one away.
Old Feb 15, 2009 | 12:17 PM
SilverBullet08's Avatar
SilverBullet08
y are you getting 6 1/2?? the back speakers are 5 1/4
Old Feb 15, 2009 | 12:20 PM
lax's Avatar
lax
the website wouldn't let me select 5.25's for some reason and when i did select them it said it was for the front I don't know why but thats what it said and then when i clicked on those it included a bracket to make them fit?
Old Feb 15, 2009 | 12:21 PM
SilverBullet08
ok what yr is your ram??
Old Feb 15, 2009 | 12:24 PM
chambers's Avatar
chambers
Lax do you have reg cab, quad cab, or what?
Old Feb 15, 2009 | 12:29 PM
lax's Avatar
lax
its a 2003 dodge ram 1500 quad cab base model (st?) short bed with a v6
Old Feb 15, 2009 | 12:30 PM
chambers's Avatar
chambers
Well b/c it's a quad is why it has 6 1/2's, so those are what you need for the rear.
Old Feb 28, 2009 | 03:49 AM
reddodge07's Avatar
reddodge07
I had the stock system in mine and decided to change it abit. Without breaking the bank. An AMP is not required. It all depends on what you are looking for. A good head unit will make it sound alot better with new door speakers. To save yourself some money, buy the adapter and install the door speakers yourself or a friend. Just my 2 cents. Good luck in your search for sound....
Old Mar 13, 2009 | 12:27 AM
Heavy_Sack's Avatar
Heavy_Sack
ok so whos replaced there rear door speakers in there quad cabs?
i am in this same dilemma now. i have a 06 everything calls for a 5.25 speakers but all i am finding from crutchfields are 6.5 and 6.75 they say they'll fit but i am asking to users here what did you actually get and was there any additional fabrication?
there website it that you need to drill new holes to accomidate the larger speakers - how hard is this?
how hard is it to take apart the door panels? any clips or just screws? I have all electric swtiches.
pretty noobticstic on mechanical work
