Alignment Issues with 20"s?
Hey guys,
I bought my truck about a month ago. Ever since I bought it it always pulled to the left a bit. It's a pretty bumpy ride as well. When I hit 60 mph it shakes a lot. The tech at the place I bought it said he road force balanced the tires and the alignment was fine but it's normal that the 20"s are a rougher ride. Is it normal that it pulls to the left a bit and shakes alot at 60 mph? Does anyone else experience these problems? I have BRAND NEW Goodyear Wrangler SR-A tires.
yes, 20s will give you a rougher ride depending on tire size. the less sidewall you have, the less cushioning you get, and the rougher the ride will be. shaking at 60+ and pulling left dont sound legit though. could be some sort of front end problem you are looking at.
when i got mine aligned guy kept saying "it's really hard to get rims this big aligned right"...what? what do the rims have to do with it?
after the 3rd try, they got it right.
Did you run a carfax history on the truck when you bought it? If the guy said it's been aligned and it's not, then maybe he needs to get his equipment re calibrated!
Larger wheels/tires can cause harsher ride simply because they are heavier when they are thrown up into the wheel well. Lower profile rubber is an attributing factor as well.
Regardless of tire size, your truck shouldn't pull. You may have a slight weighting issue that will cause slight vibration, but this is with larger off roading tires that aren't for highway use. Certainly any rim diameter that is being manufactured on vehicles these days will have zero trouble balancing out.
Could any of those things affect gas mileage? I know if I don't get it fixed then eventually it could lead to some major problems. Good thing I have a warranty though so I can get anything fixed.
Trending Topics
ive had continous problems with my alignment and i have 20's also. i just bought my truck to the dealer for the same problems your complaining about, so i ended up replacing my right rack and p/s pump as well as all 4 tires. i dont really feel like paying form the new rubber but im more then happy to get rid of the wranglers, i think they are the biggest culprit.
as far as I've ever heard, pulling has to be alignment (if front end parts are bad, they should show up there) , or shocks , unless the tires are worn funny. you could try putting the front tires on the back and vise vera to prove tires or alignment. shaking at a certain speed has to be tire balance.
