Removing Grill Frame
Old Feb 17, 2009 | 03:07 PM
TRXHemi's Avatar
TRXHemi
Question Removing Grill Frame
I know there are the screws to remove but there seems to be an adhesive holding the grill frame to the hood. Is that the case. I am talking about the chrome + outer grill surround. How do you get it off?
Old Feb 17, 2009 | 04:54 PM
TRXHemi's Avatar
TRXHemi
anyone?
Old Feb 17, 2009 | 06:14 PM
WhiteBerry's Avatar
WhiteBerry
take a nice sharp razor blade to it! thats what i did for my bug shield
Old Feb 17, 2009 | 11:49 PM
nohillbilly's Avatar
nohillbilly
I took mine off to paint it black. All I did was take off all the 10mm nuts and disconnect the hood release. It pulled off after that.
Old Feb 17, 2009 | 11:52 PM
raminator08's Avatar
raminator08
i dont what youre talking about when you mean the adhesive. when i replaced my grill frame, all there was jus the screws. there was that rubber around the top of the grill so it didnt bang against the hood when you screwed it tight.
Old Feb 18, 2009 | 06:32 AM
TRXHemi's Avatar
TRXHemi
I am talking about the rubber around the top - is it sticky? I removed all of the screws once, and it seemed to be still stuck on there. Maybe I missed a screw or something. Just wondering....
Old Feb 18, 2009 | 07:10 AM
MikeHTally's Avatar
MikeHTally
The "gasket" still had some adhesion when I removed my grill. I would recommend a plastic chisel, rather than a razorblade.
Old Feb 18, 2009 | 07:53 AM
MOPAR78's Avatar
MOPAR78
I did the same as WhiteBerry. Once all the bolts are out, gently pull on one side or the other where it's stuck and carefully insert the blade. Cut and gently pull at the same time and it will pop right off with no problem. Or at least mine did.
Good luck!
Old Feb 18, 2009 | 09:51 AM
oefootball_70's Avatar
oefootball_70
Did you get it off?
Old Feb 18, 2009 | 10:08 AM
TRXHemi's Avatar
TRXHemi
I have not tried yet. I was planning on painting the grill soon, and was just preparing.
