Truck Randomly Dies
Old Feb 19, 2009 | 11:39 AM
oefootball_70's Avatar
oefootball_70
Default Truck Randomly Dies
Has this happened to any of you guys? It will die whenever it feels like sometimes in the middle of the street. I am worried on of these times I am gonna get in a wreck because of it. I am not throwing any codes either. Any help would be appreciated.
Old Feb 19, 2009 | 11:49 AM
ried69's Avatar
ried69
New vehicle, these dealers can't fix that problem. I don't know what is causing it, but that happened to my grandparents Jeep. Slow down for corners, started sputtering just before they got rid of it. It was in at the dealer, driven for 100 miles or more, and they found nothing on it. No codes, just died randomly on my grandma, and only got worse.
Hope that doesn't happen to you, and is just a minor problem, but I know that happened to my grandparents.
Old Feb 19, 2009 | 12:05 PM
02Steve1990's Avatar
02Steve1990
Mine usually dies when its a colder morning and i let it warm up for about 10 mins then i start driving..the gauge for the engine is still pointing towards the "C" when I get to a traffic light then my rpm's drop below 500 and then to 0 so i just restart the engine..it only does that sometimes when it cold outside but it hasn't happend in a while now..still have no idea why that happens
Old Feb 19, 2009 | 05:19 PM
OlDirtyJohn's Avatar
OlDirtyJohn
how exactly is it dying on you? in my durango right before my PCM totally took a ****, the lightning bolt light would come on, the engine would die, and i would lose power everything. then id pull over (just barely), wait for a couple min, and itd start back up and run again.
Old Feb 19, 2009 | 05:54 PM
RodeoRamCowgirl's Avatar
RodeoRamCowgirl
I never have had that problem in my colbalt... yet but I think I just jynxed myself there... 41k strong...
Its happened to me in the trucks at work though, depending on how long you had the battery maybe check the connections, cords and the battery itself... usually 1 of the 3 is the reason for this... even when it dont throw a code...
Old Feb 19, 2009 | 06:06 PM
HammerZ71's Avatar
HammerZ71
seen it on the Hemi's with some '04 & '05s, PCM flash was the fix...
Old Feb 19, 2009 | 06:24 PM
ramhunter9's Avatar
ramhunter9
how would the fash fix a problem that hasnt been diagnosed yet. dr. house i mean hammer?
he really needs to figure out what the problem a flash seems like a bandaid at this point?
Old Feb 19, 2009 | 07:07 PM
HammerZ71's Avatar
HammerZ71
It was a glitch in the actual tune on the stock PCM, not saying this is his problem, but I know some Hemi's through '05 had the issue and the fix was flashing it with the updated tune...
Old Feb 19, 2009 | 10:41 PM
ried69's Avatar
ried69
My truck had a six year old battery in it, and I never once had a problem with it, as far as doing that. So I don't think his actual battery itself is the problem, not when mine lasted so long.
Old Feb 19, 2009 | 11:10 PM
Pyro's Avatar
Pyro
I Beat Tetris
You've got the 4.7L right OE? Mine did this about a month after I got my truck, wouldn't rev right, low idle and would sometimes cut out. Problem was a bad Throttle Position Sensor, $20 fix.
