Where to get longer shocks?
Old Feb 26, 2009 | 10:16 PM
MikeHTally's Avatar
MikeHTally
Originally Posted by Thatonekidw/theHEMI
How does it ride MikeHTally? No bottoming out?
No bottoming out and when I "get air", it hasn't yanked out the shocks yet :-) No bouncing after railroad crossings and handles great (the Hellwig sway bar helps there). Twisties are lotsa fun! BTW, a level kit should reduce the chance of bottoming out -- you're starting with the shocks extended another two inches or so.
Old Feb 26, 2009 | 10:20 PM
bigwood's Avatar
bigwood
how much of a difference did a new sway bar make? and did you get fancy eurethane bushings?
Old Feb 26, 2009 | 11:13 PM
06CountryBoy5.7's Avatar
06CountryBoy5.7
Originally Posted by Hoss356
06-08 1500 level kits are a spacer that sits on top of the coil over/strut assembly therefore a longer shock isn't needed since the spring and the shock are both relocated down 2.5". http://www.automotiveconcepts.net/st...medium=organic
94rt10ohio did a write up on it: https://dodgeforum.com/forum/3rd-gen...dbeardmcg.html
ya sure....you dont have to install new shocks...but you will bottom out eventually and if you do any kind of off-road driving BANG! not to mention the wheel travel is so limited.
Old Feb 27, 2009 | 10:35 AM
HEMI07's Avatar
HEMI07
On the 06-08 1500's, the 2.5 in leveling spacer should not change the shock travel at all from stock. The spacer bolts to the top of the entire strut assembly. However a Rancho or Bilstein will ride better than stock anyday
Old Mar 6, 2009 | 11:19 PM
Hoss356's Avatar
Hoss356
Then you're not asking for a longer shock, rather a quality aftermarket one with adjustable preload and rebound. I've been looking for something along those lines as well, that is until I can afford a Kore or Carli lift. Anyone know if Fox or bilstein make direct bolt in replacements, for those of us who have the struts, yet?
Old Mar 10, 2009 | 07:37 PM
Hoss356's Avatar
Hoss356
bueller... bueller... bueller...
