HID problems anyone on 9007 kit
Old Feb 27, 2009 | 02:42 PM
xenoneyes's Avatar
xenoneyes
Default HID problems anyone on 9007 kit
Has anyone here have a 9007 bi xenon or single beam hid kit they've bought but has the flashing problem? If you do please let me know , i think i have found a plug and play solution but i would like to test it on a few different vehicles first.
Old Feb 27, 2009 | 03:47 PM
dirtydog's Avatar
dirtydog
Moderate User
Depends on the kit? Cheaper one's will flicker on the Chrysler's since they utilize a canbus system. A cancellor kit is required to prevent this.
Old Feb 28, 2009 | 04:41 PM
xenoneyes's Avatar
xenoneyes
we've tried cancellor kits before on this vehicle. No luck @ all. how much do the "expensive" kits run?
Old Mar 1, 2009 | 02:31 AM
Kamel87's Avatar
Kamel87
i have the flashing problem all i do is turn them on before i turn the car on and they dont flash but if im driving sometimes im afraid of driving aroudn with flashing lights
Old Mar 1, 2009 | 09:18 AM
Romeosoldier03's Avatar
Romeosoldier03
i had the same flickering issue...look like strobe lights....anyways...the guy who installed them wired them straight to the parking lights wire since the headlight source runs off of a different signal he said....but mine work great.....fogs and heads..
Old Mar 3, 2009 | 12:19 AM
sharkhunter10's Avatar
sharkhunter10
What you need is a relay! It stops the flickering and shuting off. I had the problem till I contacted the company and they sent me one and it has worked ever since here is what it looks like!
Old Mar 4, 2009 | 10:28 PM
bigpappaholt's Avatar
bigpappaholt
i got something just like this when i got my hids, my box thing looks different than yours but mine still flicker
Old Mar 5, 2009 | 01:29 AM
Kamel87's Avatar
Kamel87
try turning on ur lights before u start ur engine for about 5-10 seconds i have that same problem but when i turn the lights on before the engine not a single flicker
Old Mar 5, 2009 | 07:17 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Over on Dodge Talk (dot) com there is a vendor that sells HIDs made for our trucks and a guaranteed not to flicker or strobe. He does not use resistors or cancellors either. They are 5th gen ballasts. We just had a groupbuy and he gives lifetime warranty on his bulbs and ballast. I started to buy a cheper kit on ebay but then when i got to thinking about what it would cost to replace the bulbs or a ballast plus the problems I knew I was going to have with it flicker just wasnt worth it to me. Thats why I bought hit. In the group but I bought Bi-Xenon 6000k 9007 and single beam (fogs) 6000k 9006 shipped for a little over $300
dodge talk.com/forums/showthread.php?t=240238
Old Mar 5, 2009 | 08:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Also you can look here at this thread on how to resolve those issues you are having
Found a Fix To My HID Problem, LAMP Out & Strobing
Dodge Talk . com/forums/showthread.php?t=231858
