3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Yes, and if I had been able to just order it & wait for it, I might have been able to get one like that. Unfortunately, anything that came with a Hemi on the lot, ALSO came with a laundry list of related (and unrelated) options that added up to just under six grand.
Even so, a grand for 35 more HP? Still not worth it in my book.
Yea the options add up fast....and peak numbers aren't everything.
the intake tube ( that says airraid on it) I know its kinda hard to tell with the way the pic is
I'm not ball-busting; just asking a question. Did you get the intake tube and a Airaid filter for the stock airbox for $100.00, or just the tube? I got the entire Airaid CAI package for a little over $200.00.
I only got the tube part because the area where i live, I drive down alot of dirt roads and I didn't want the whole exposed air filter thing.and from what I looked at I thought $100 for some kinda intake system wasn't that bad
I can understand that, but are you going to install a replacement Airraid filter over the stock filter in your airbox, or just continue to use the stock filter?
I'm going to use the stock air box part so its enclosed but i put a K&N air filter in instaed of something like a fram.I know its not much but it did wake up the little 4.7
Ok, that's where I was going. Sounds good, doesn't it?
