Removing the LSD Clips? Possible?
Old Mar 6, 2009 | 05:52 PM
Trigger's Avatar
Trigger
Question Removing the LSD Clips? Possible?
I already did a search on the subject. However, I didn't get positive info on it.
How many of you have simply removed the clips in the factory diff when doing a fluid change will no ill effects?
How many miles have you driven since then?
I found after searching the posts that they can be pulled with a 30 or 45 degree needle nose. This seems like a very cheap alternative to replacing it with an aftermarket one.
What are your thoughts?
Old Mar 6, 2009 | 07:17 PM
MikeHTally's Avatar
MikeHTally
When I did my diff fluid change, I kinda looked into just breakin' 'em out, but they're in there very securely and I didn't want to get them partly out and not be able to finish, so I just left 'em.
I agree, that would seem to be a very cheap alternative to a whole new gear set.
Old Mar 6, 2009 | 07:26 PM
Trigger's Avatar
Trigger
I suppose the argument is that some folks have replaced the entire rear end after finding the clips on the magnet. What nobody is saying is how long have they been driving around with the pieces on the magnet and didn't even know it.
So if this is the case, what's the harm in just yanking them out? I hope to hear from someone who has done this. Before I ruin my diff.
I don't have the money right now for a DTT, but I'd like to feel better about my diff. Wouldn't we all?
Old Mar 6, 2009 | 08:40 PM
traker1001's Avatar
traker1001
but does the LSD actually work with them out?
Old Mar 6, 2009 | 09:08 PM
Trigger's Avatar
Trigger
That's what I'd like to know
I'm more concerned with binding or total destruction of the rear diff.
Old Mar 6, 2009 | 09:53 PM
KKYW Ram 7's Avatar
KKYW Ram 7
I am not 100% but I do remember reading that the clips can safely be revoed with no ill-effects, but it will no longer function as a limited slip, it will just be a normal open differential.
Old Mar 6, 2009 | 11:29 PM
traker1001's Avatar
traker1001
I want to keep my LSD functioning, if it grenades or the clip just comes out, It's still under warranty Ill let them replace it. When its not under warranty... We can rebuild it, we have the technology, We can Make it better, Faster, Stronger...
