tranny code 732 help
Old Mar 7, 2009 | 06:47 PM
shelbydog25's Avatar
shelbydog25
Question tranny code 732 help
while towing, from a stopped position to start up, the engine reved high between 1st and 2nd gear, then seem to settle on 3rd gear. The check engine light came on, code PO 732 (gear ratio error in 2nd gear)... as well as code PO 700 (transmission control system). after unhooking my load the truck seemed to perform normally (albeit I didn't step on it from take off being 3 hrs from home).
anypoint me in the right direction on this? tranny going bad? does the PCM need a reflash due to a "power surge" on acceleration?.. this truck hasn't towed much
Old Mar 7, 2009 | 07:35 PM
HammerZ71's Avatar
HammerZ71
What model truck? What engine? How much weight? How far?
Old Mar 8, 2009 | 01:06 PM
shelbydog25
2004 Quad cab, hemi, 45 miles distance while towing, 5000 lbs.. well within the capabilities of the truck..
Old Mar 8, 2009 | 06:46 PM
HammerZ71's Avatar
HammerZ71
Pull the stick on the tranny fluid, look at it, smell it. Is it discolored, like brownish, does it smell burnt?
Old Mar 9, 2009 | 06:30 PM
shelbydog25
model 1500, color is pink, not overly bright pink. no strong odor of any burnt smell.. a tranny flush and filter change?
