Lawn mower battery jump start off the Ram??
Old Mar 8, 2009 | 12:02 AM
DaHipaKea1313's Avatar
DaHipaKea1313
Default Lawn mower battery jump start off the Ram??
Hey I know this isn't a 3 Gen question but doese anyone know if I can jump start a 6 volt lawn mower with my Ram. I don't want to blow up anything especially the truck
Or I have a 12 volt charger. Can I it to charge the 6 volt battery?
Old Mar 8, 2009 | 12:23 AM
R1mark's Avatar
R1mark
not really sure but i would say not a great idea. that would be like taking a 120v from your house and tring to jump start your truck. (without a charger)
But hey theres on harm in trying really whats the worst that could happen the battery still junk
Old Mar 8, 2009 | 03:35 AM
Hoss356's Avatar
Hoss356
R1, your analogy is very poor, 12 to 6 volt isn't anything like AC to DC current! If you did try jumping a 6 volt off a 12 nothings gonna happen to truck but a 6 volt starter is another thing... that may exceed the starters capability and possibly other circuits on the mower depending on how advanced the circuitry is on that thing. As far as charging goes, some battery chargers can charge both 6 and 12 volt batteries, but the ones I'm familiar with have a switch to go from 6 to 12, I'm not saying that you can't do it, I wouldn't be surprised to see a charger the reads the battery you are charging and applies the correct voltage, but I'd check the manual first. Some of those mowers can get up there in price now days and I wouldn't try to just rig something that may or may not work without knowing before hand.
Old Mar 8, 2009 | 07:55 AM
lxman1's Avatar
lxman1
Site Moderator
Most riding mowers are actually 12V. If it is 12V, yes you can jump it.
Old Mar 8, 2009 | 11:21 AM
Rojhan's Avatar
Rojhan
If it's actually a 6-volt system, you can melt stuff. The system has certain resistance based on the combination of all of the components. Current (amps) draw is voltage divided by resistance. So, if you double the voltage you will double the current draw (roughly, it's not a purely resistive system).
Think of what would happen if you tried hooking up driving lights to the wires that are used to run your dash lights (not as extreme, but the concept is there).
As an additional note, the electrical system of a lawn mower isn't going to have all the nifty filters and other systems to "clean" the power. You could backfeed really noisy power back into your truck and make your electronics very unhappy.
I would think twice about trying to jump start a lawn mower, even if it was a 12 volt system. If you really need to do it, disconnect the ground wire on the truck battery and just use it as a booster battery. The truck battery by itself (without the truck running) would have more than enough power to get the lawn mower going even if the lawn mower battery was dead.
Old Mar 8, 2009 | 12:45 PM
Redone4x4's Avatar
Redone4x4
try calling your local parts store to see if they charge batteries. I know autozone out here does it for free, i would just do that. takes about an hour and then u are safe all the way around.
Old Mar 8, 2009 | 02:10 PM
MikeHTally's Avatar
MikeHTally
Using 12V to charge a 6V battery is dangerous. Are you sure it's 6V? I've jumped my JD off the truck a time or two, but it's 12V.
Old Mar 8, 2009 | 02:21 PM
raminator08's Avatar
raminator08
there is no other car near you that can help you jump start?
Old Mar 8, 2009 | 02:25 PM
dodgenitto's Avatar
dodgenitto
I would just disconnect the cables from your truck and use just the battery (just to be safe) I had a battery from my old truck sitting in my garage and I charged it and used it to jump start an old snow blower.
But I don't recommend using the charger on a different volt battery.
Old Mar 8, 2009 | 11:14 PM
DaHipaKea1313
I guess I never looked and just assumed it was a 6 volt It is a 12 volt and I just connected up my charger to it and it's working fine after about 4 hours on it. Thanks for the help.
I just remember my grandfathers being a 6 volt for such a small motor so I just thought mine was the same. Thanks
