Quad cab rear speakers
I currently have a head unit on order and want to change the speakers in the doors of my 06 QC. How hard is it pull the door panels? Any good photos out there of what all needs to be done.
Are there clips or just the screws?
Thanks...
Thanks...
As for the rear panels, its just the bolt behind the door handle and two screws at the bottom of the panel i think. Then just lift all of the up and out and be sure to disconnect the wiring harnesses.
On the front panels you get the big screw in the top front corner by the mirris and another one in the center of the panel. I think there are two smaller ones at the very bottom of the front panels and there is a small bolt behind the door panel. Sorry I dont remember what size it is.
If the wires are still ran to the HU then yes you should be able to plug in play. But I wouldn't be so sure if the speakers are gone. I'd look into a little more.
