lift kit question
Old Mar 11, 2009 | 09:10 PM
mcgoo89's Avatar
mcgoo89
Default lift kit question
im new to the site and i have an 02 1500 4.7l, with a leveling kit... i want to lift it up and im wondering what the negatives are. any problems with it afterwards? and should i go suspension lift or body lift? thanks everyone
Old Mar 11, 2009 | 09:32 PM
mmstar23's Avatar
mmstar23
if you go suspension you loose your leveling kit. suspension kits are setup to be 2" higher up front to level it out. you can always go with body lift and basically have a 5" lift, or you can start over and go with suspension. some people are against body lifts due to the fact you need to lengthen brake lines along with other things. some have also said the blocks "creak" over time. im running a 2.5" leveling kit along with a 3" PA body lift. no complaints, except you do need new shocks to go along with your leveling kit because the rides not so great. if your going for looks i see no problem with the leveling kit and body lift setup. if you plan to offroad or want a better riding truck, id opt for a suspension kit.
Old Mar 11, 2009 | 09:36 PM
mcgoo89's Avatar
mcgoo89
how much did your body lift cost installed?
Old Mar 11, 2009 | 09:41 PM
mmstar23's Avatar
mmstar23
bought it with the truck. couldnt tell you prices. although im pretty sure theyre a little over $300 for the kit itself and nearly just as much for the install
Old Mar 11, 2009 | 09:48 PM
mcgoo89's Avatar
mcgoo89
can anyone help me out on this? prices/problems for the body lift?
Old Mar 11, 2009 | 10:04 PM
mmstar23's Avatar
mmstar23
http://www.4wheelparts.com/Lift-Kits...&t_pn=PER60083
somone may know of a cheaper place.
Old Mar 11, 2009 | 10:06 PM
HammerZ71's Avatar
HammerZ71
Go here, read, you'll learn a lot. And yes, there will be a test!!!
https://dodgeforum.com/forum/off-roa...uck-101-a.html
raminator08's Avatar
raminator08
check in the 3rd gen FAQ forum. everything about lifts should be there when you find the lift thread
Old Mar 11, 2009 | 10:38 PM
Redone4x4's Avatar
Redone4x4
4wd or 2wd?
Old Mar 12, 2009 | 12:01 AM
mcgoo89's Avatar
mcgoo89
it is 4wd
