New Owner Question
Old Mar 18, 2009 | 03:24 PM
HuddMW's Avatar
HuddMW
Default New Owner Question
Hi Everyone,
I'm a new owner of 08 Ram 1500 3.7 V6. Have done some personalization on the truck and duals with a Thrush 1 in 2 out muffler. Not quite a v8 sound but still sound good. My question is will a cold air intake that fits an 07 fit an 08. Seller doesn't know. I called Dodge and they couldn't give me an answer since it's aftermarket. So here I am at the experts place asking. Any help appreciated.
Old Mar 18, 2009 | 03:38 PM
chambers's Avatar
chambers
Which intake is it? It should fit as from 04 to 05 is when they changed some layout under the hood.
Old Mar 19, 2009 | 07:19 AM
7mmmag1's Avatar
7mmmag1
most likely, i havent seen under the hood of an 08, but it cant be much different than my 06 or redbuds 07
check ebay cold air intakes with a k&n filter, they are cheap and work pretty good
Old Mar 19, 2009 | 03:16 PM
HuddMW's Avatar
HuddMW
Thanks for replies guys. Here's the intake and they have again answered me that they don't know. Hell of a way to do business.
http://cgi.ebay.com/ebaymotors/ws/eB...72937&viewitem=
Old Mar 19, 2009 | 04:39 PM
chambers's Avatar
chambers
I can't think of any reason that wouldn't fit. You could always get a different coupler if the one they send with it doesn't fit. Are you planning on doing a ram air hood or something?
Old Mar 19, 2009 | 08:27 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
if you're gonna run that dual thing, just stick a filter directly onto your throttle body.
air isn't gonna be much cooler (not that .1 degrees makes a difference), and there is less tubing for it to go through. get some headers first.
and if you don't know, go find an 06 or 07 and look under hood and compare. does it look similar? then it fits.
Old Mar 19, 2009 | 10:50 PM
raminator08's Avatar
raminator08
i think it should be fine. maybe the only difference is the air sensor might be on the other side. when i got my CAI, i had make a new hole in the pipe on the other side for the sensor
