Need advice on '08 dodge ram
Old Mar 20, 2009 | 11:13 AM
THEBOYZ1303's Avatar
THEBOYZ1303
Default Need advice on '08 dodge ram
I own a 2008 dodge ram 1500 2wd, and im trying to decide on getting a 3" body lift or buying a suspension lift. I'm not going to use my truck for any type of off roading or anything like that. I just want to give it the look. When i do put some sort of lift on my truck what size tires should i put on it? I've just installed a 2" leveling kit also, i just want to go a little higher. So any advice and pics would help a lot.
Old Mar 20, 2009 | 11:30 AM
dirtydog's Avatar
dirtydog
Moderate User
Honestly if i were you, I would just go with a basic block lift for the rear and get spindles for the front. Since you have 2wd, spindles would be the cheapest and effective for a pavement queen. And you still retain stock ride quality. I would get new longer shocks for the rear with the blocks. You should have installed longer shocks for the front while you had everything apart but since your on asphalt all the time, no big deal. Your suspension travel is slighty limited. But def get longer for the rear because if you haul stuff, your more likely to notice the difference.
Old Mar 20, 2009 | 12:46 PM
04-fourseven's Avatar
04-fourseven
I guess you just want that "HEMI" look. lol
Old Mar 20, 2009 | 08:24 PM
THEBOYZ1303
Thanks for the replies ill take it into consideration, and i guess i am going for the hemi look
Old Mar 21, 2009 | 12:20 AM
lxman1's Avatar
lxman1
Site Moderator
Hemi look????
