diablosport
Old Mar 20, 2009 | 04:23 PM
bloodySUNDAY134's Avatar
bloodySUNDAY134
Default diablosport
ok, my question is this. i have uploaded both the 87oct and 93oct performance tunes on my rig and have gone through a tank of gas with each one. i'm having a slight problem, when i come to stop or start from a stop, like when i'm just creeping, my rig seems to hesitate a bit and then it surges as if the fuel has been pooling and building up and then it's just shooting through in one big burst. is this common? should i get some fuel injector cleaner to clean out my injector? also, when i upload a performance tune, does it automatically shut off my mds or do i need a separate program for that?
Old Mar 21, 2009 | 12:28 AM
lxman1's Avatar
lxman1
Site Moderator
Mine has not had that issue with any of the tunes. I use a bottle of injector cleaner every 3K at each oil change.
To turn of the MDS, pull up performance tunes and pick the one that you want, say 93 octane. Then after it runs thru it's check, it will say install tune and modify tune. Click modify tune. Then scroll down to MDS and you can turn it off there.
Once you load in the MDS off, it will stay off even if you switch to 87 or 91 octane tunes. It will come back on if you either turn it back on manually, or if you restore the stock tune.
I found that any of the modifications made to a performance tune, carries over to the other two performance tunes without having to reload them, unless you go back to the stock tune.
I get the best mileage running 93 octane with MDS on. On a fairly level highway, I average about 22.3 mpg @ 65mph.
On average mixed driving, I get about 17.8.
Old Mar 21, 2009 | 01:16 AM
dedogg's Avatar
dedogg
I cant wait to get mine......
