Installed my Hellas???
Old Mar 21, 2009 | 09:51 PM
SilverBullet08's Avatar
SilverBullet08
still didnt get it to work...im done for tonight gonna look at it tomorrow
is the relay even worth using? or just hook it up to the battery
Old Mar 21, 2009 | 09:53 PM
Alpheus's Avatar
Alpheus
unplug the relay and take some spare wire and connect 86 to pos and touch 85 to ground. You should gear the relay make a clicking sound when you touch the neg. If not you have a bad relay...
Old Mar 21, 2009 | 09:55 PM
MikeHTally's Avatar
MikeHTally
Behind the knee bolster is a normally not-used harness. Four wires, if I remember correctly. One of those is a switched-hot (violet/black, I think, but confirm with a meter). Take that switched hot to your rocker switch. Continue from the rocker switch to one leg of the low-current side of the relay. Put a 3A fuse in there somewhere (probably before the switch). Then ground the other leg of the low-current side. Take a HEAVY lead from the battery positive through an appropriately-sized fuse to a leg of the high-current side of the relay. The last connection is from the other high-current leg of the relay to the lights. The only other connection is to ground for the lights.
You can use the hot side of the high beams to trigger the low-current side of the relay. You can use the rocker switch to interrupt that, if you want. Yes, you DEFINITELY need the relay. Make sure you fuse it all, so you don't let the smoke out.
Old Mar 21, 2009 | 09:58 PM
nim81's Avatar
nim81
Originally Posted by SilverBullet08
what color is that?
should be green
SilverBullet08
thanks guys ill try that tomorrow and let you know how it goes...
Old Mar 21, 2009 | 10:00 PM
SilverBullet08
Originally Posted by nim81
should be green
ok the green wire i have going from the relay to the rocker switch. the rocker switch has three slots. two short and a long one in the middle. i have the green wire in the longer one and the yellow wire in one of the short ones
Old Mar 21, 2009 | 10:10 PM
Alpheus's Avatar
Alpheus
12 vdc in the middle
Old Mar 21, 2009 | 10:48 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Well they look good on your truck, sorry that they don't work yet. Are you sure that your relay isn't bad?
Old Mar 21, 2009 | 11:06 PM
SilverBullet08
i have no idea. as you can tell not really good with electrical stuff lol
Old Mar 21, 2009 | 11:09 PM
Off_Road_Teacher
Well I ordered a set this morning, if you can wait until mine come in I can help you troubleshoot when I install mine.
