Stalls/Bucks at Full Throttle
Old Mar 22, 2009 | 11:11 PM
RPM12's Avatar
RPM12
Thanks ... how do I recalibrate?
Old Mar 23, 2009 | 12:40 AM
Rebeltilldeath3's Avatar
Rebeltilldeath3
How mechanically inclined are you? Any good with a multi-meter?
Old Mar 23, 2009 | 12:48 AM
kylanmoore's Avatar
kylanmoore
Yes I just joined because I am experiencing the exact same symptoms with my 02 5.9L. When floored it runs perfect tell about redline and it sounds like its just bouncing off the limiter then I have to left off and slowly give it gas again.
Old Mar 23, 2009 | 12:53 AM
Rebeltilldeath3
If it's hitting redline and sounds like it's bouncing off the limiter, more than likely it is.
You're describing something totally different than the OP.
Old Mar 23, 2009 | 01:14 AM
kylanmoore's Avatar
kylanmoore
Yeah but it doesnt shift out of 1st when floored from a stop. I have to let off and gently give it gas tell it shifts then I can floor it.
Old Mar 23, 2009 | 09:46 AM
HammerZ71's Avatar
HammerZ71
1) Turn the key to run (don't start the engine)
2) Wait about 5 seconds for the dash lights to got out. Slowly press the gas pedal to the floor and slowly let it back up. You should hear a confirmation "ding" sound when the pedal comes all the way back up.
3) Turn the key off...
Old Mar 23, 2009 | 10:18 AM
talon6's Avatar
talon6
yeh you are probably hitting the limiter.mine limits out before it hits the redline too. and you do know that we still have the junky trans in our trucks donnt you?
Old Mar 23, 2009 | 01:10 PM
RPM12's Avatar
RPM12
Damn Hammer, if that fixes it that easy ... you'll be like my new hero ... man! I'll give it a try soon as I get home and let you know. Thanks
Old Mar 23, 2009 | 01:32 PM
magnethead's Avatar
magnethead
even though mine is a dakota, sound's "normal" to me, limiter wise. my 3.9 does same.
as to shifting, my typical suspect would be the pesky TV cable.
Old Mar 23, 2009 | 01:34 PM
HammerZ71's Avatar
HammerZ71
well it's not a certain fix by any means, but you start with the cheapest, easiest on the list of possible culprits to a problem, and this should be your starting point. I mean it could be that your injectors are not getting the proper fuel into the chambers at WOT, it could be any one of a dozen things, but this should be the starting point.
And it does often fix the issue...
